Cars & Trucks Logo
Bill Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan that controls the A/C and heater is stuck in the on position & running full blast. Puching the off button or manually puching the fan buttons does not do anything. The fan continues to run full blast.
10acT
Level 2:
New Friend:
  • Expert 36 Answers
  • Posted on May 09, 2011
10acT
Expert
Level 2:
New Friend:
Answers
36
Questions
0
Helped
13728
Points
112
Sounds like a problem with the fan switch. If you can find the fuse for the blower motor, you could pull the fuse to stop the fan until you can get the problem fixed.
Turned the heater and car off but fan keeps blowing - now cold air - at full blast. had to disconnect battery to get it to stop
car has electronic issues
tow to an auto electrician or impala specific workshop
burnt out fan motor
faulty climate control wiring or sensor
faulty relay
check if direction flap motors or actuators are working
Where is the ecm
some do some dont.. parts store or dealer service can tell you
The heater only blows on full blast, the first three positions on the button does not work. the car is an 2006 Chevy Aveo LS hatchback
In the heater plenum behind the glove box you should find a 4 or 5 wire connector. That is called the heater resistor it has a series of different thickness springs and controls the Resistance to ground. That is what controls fan speed. First check the connector for melting if so you need to replace the connector and resistor if not remove the two screws holding the resistor in place and remove the resistor, you should find the springs are broken and replace the resistor. Note there are a couple of other things that can cause this problem but 99% of the time its this.
The fan is stuck blowing on high, the knob turns etc... but the fan and condenser run full blast
Check the connection at the heater blower motor resistor.Wiggle or pull connector off and look for a melted pigtail these get very hot and usally are the cause of fan motor problems.Its located on passenger side of heat duct mounted with 2 screws.
4helpful
3answers
1997 Pontiac Grand Prix overheating in stop and go traffic
its either of the 3 ur water pump is weak and couldnt supply the right amount of coolant to ur engine / ur radiator is clogged or your thermostatic valve is stuck up that restrict full flow of fluid to the radiator thats why when u use the heater that uses ur coolant hot water as a heating unit the temp. goes down...
I have a 92 cadillac deville and the fuel data and climate control screens both show a 'c' on them and the heat is on full blast?
the heater is in limp mode if you have electricity experience go to the library and get a manual because that heater does a wack of **** and you need to know how to press the right two buttons at once to get into the heater menus in the actual heater control
Ac problem
I just fixed mine. same problem, no ac light no fan. inside the heater control assembly there is a electric wiper arm on the fan switch. This arm connects all power for fan and ac. Mine broke out of the fan control switch. Dash is not too much problem to get out. Have to pull top dash center section out by puching forward and lifting out. pull all screws on center dash counsel. remove radio, two side covers that hide screwsand lower trim that holds emergency flasher switch. remove cables from heater control and wires and remove. Took me about an hour. The code on radio will need to be reset so make sure you have that handy. Hope this helps..
1helpful
2000 sebring convertible - heater fan only blows on full blast,
you need to replace the resister block for the fan speeds... it is located in/on the duct work near the fan. you will see a connector and two or three screws holding it in.
Robert
Please take a moment to rate this solution thanks
Top Infiniti Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Infiniti Expert? Answer questions, earn points and help others
