I have a Samsung LE40F71B LCD tv about 18 months old. It has started showing red pixels around the edges of blacks, e.g. around a lapel on a black coat or on black hair, etc. Sometimes the sound crackles too, then is ok. The screen may flash very briefly at that point, then is ok again.
  • Anonymous Aug 15, 2008
    We've got exactly the same problem with our Samsung, purchased in November 2006. Spoke to Samsung about it, they don't want to know as its out of warranty, even though they had to replace the main board shortly after we got it. They suggested someone to fix it, but they want £120+VAT to even come and look at the thing!
5 Suggested Answers
davebies
  • 43 Answers
SOURCE: Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Posted on Jan 06, 2008
SOURCE: Samsung LCD HDTV - Color Problems
voltage adjustment for y-sus board or power supply
Posted on Mar 17, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
SOURCE: Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Samsung LCD LN52A650AF - Glittery Red Green Screen Pixelations that moves around with changing figures on the picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
May 14, 2017 | Samsung LN52A650A LCD TV
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
I have red dots or pixels if u will spreading all over my 50 plasma its really bad on pure black screen but it does show up when it goes to color too they come and go is it a graphics card problem and is...
It depends on the size,location and how many dead pixels. If remember less that 5 they won't do nothing about them. Call the warranty people and find out. they will for the location, size of pixel and quantities. Good luck to you.
Nour Sabre
Nov 03, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Black pixels in shading and back ground turning red
This is not a "rear projection" plasma TV for whiuch you offered solutions, It is the LCD Flat panel the Liquid Crystal Display a 40" Samsung. I do not think this problem is a dead pixel as that woulde be "black" Reading on the web I found only one post that appeared to be the same or similar and the person said somehing about "switching the red wire" Maybe it is a "stuck" pixel -- sticks on red once in a while. Like previously after the first time it occured it has not come back in three days now. Samsungs repair comes today i will cross my fingers.
Jun 29, 2009 | Epson Livingstation LS57P2 57" Rear...
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Aug 28, 2008 | Memorex MLT3221 32 in. LCD TV
Black/Dark Colors Fuzzy w/Red Pixel Outline
Sorry, I haven't been on here for a while.
I haven't found the cause. I find that leaving it switched on overnight cures it.
Feb 18, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
