Question about Draytek Computers & Internet
Connecting 3 mobile internet dongle to draytek 2800vg via its usb port
    Genius:
  • 1,269 Answers
Make sure to install the drivers that came with the internet dongle. Just run the setup CD the that came with it, when it asks you to plug the dongle, please do. That should guide you through the whole setup process.
Posted on Nov 01, 2008
SOURCE:
How to config vlan on switch 3cdsg8 and a router draytek 2920
You can configure trunks TRUNKS > Configuratio
n.
You can configure port to be part of that truck via TRUNKS > Members
Jun 16, 2014 | Draytek Computers & Internet
Hi Team, I have a Draytek Vigor 2700 Router. I have redirected ports 80 , and 34599 to view my DVR cameras at my office. I have a static IP and i can successfully log into my DVR via HTTP port 80,...
It is an issue the Draytek and your phone.
Draytek displays as a web page. It uses HTML or XHTML
In order to see it on your phone it needs to be coded in XHTML Mobile 1.0
Jul 02, 2011 | Draytek Vigor 2700 Adsl2/2+ Router 2 Vpn /...
What is Bluetooth Dongle?
Hi message4,
Welcome to FixYa! How are you doing?
Bluetooth Dongle is often refer to USB Bluetooth Adapter, it is a device which you connect to your computer via USB port to allow data transfer from your PC or Laptop to Car Kits, Mobile Phones, PDAs, GPS Receivers and much more.
Hope that helps. Thank you for using FixYa.
May 01, 2011 | Acer Aspire™ T180 PC Desktop
How to connect pc with micromax Q5 mobile. I am using vodafone prepaid connection.
you connect via a usb cable or bluetooth which is a wireless connection. if you have tried connecting with a usb cable, what happens? If the device cannot be seen or recognized by your pc the most common reason is that you dont see a device you plugged in is that you dont have the proper drivers installed on your pc. See what error meesages you get, and troubleshoot! Are you saying your internet connection on your PC is via vodafone usb dongle? This should not affect your ability to connect a mobile phone via a usb cable which should work without being connected to the internet. Its all a question of hsving the correct drivers, but some software wont work with the dongle software, which has to be uninstalled. Troubleshoot for the correct drivers them get technical help from micromax
Dec 27, 2010 | Computers & Internet
3network mobile dongle wont work
Three options:
1). Try another USB port on the PC / Laptop. I have discovered that some USB ports mess up sometimes.
2). Check if you have a firewall software on this computer (some of those that normally pops up with messages at the bottom-right of your screen saying things like 'Allow, Block, etc". If you have one of such, you may want to go into the setting and disable firewall briefly and test your Dongle again. If it now works, then Allow the Dongle in the firewall settings.
3). Uninstall the Dongle. Shutdown and restart your computer. Go to Program files and delete the folder where the program was installed. Then use the CD that came with your Dongle to do an install. Then finally connect your Dongle. Should work.
Apr 27, 2010 | Dell Dimension 4600 PC Desktop
Unable to connect my pc to 5800 for internect by blue tooth . do i need blue tooth modem on my comp
yes , n the name of the device is bluetooth dongle which can b easily connected through USB port and also u will get driver with tht dongle just intall it n thn connect ur phone .
secondly if ur question is u want to get internet access in ur mobile from pc then u must hv wifi modem of internet.
also u can access net in your mobile by using a software Gnubox and mRouter and bluetooth dongle in ur pc
hv fun
Mar 14, 2010 | Nokia 5800 XpressMusic Smartphone
I have recently bought an EPC netbook, internet problems
3 mobile are correct. You cannot use the USB modem dongle that 3 supply to access the internet. That dongle requires application software to allow internet programs to access the port and so access the modem in the dongle. Windows CE does not allow this access. Find out which modem chip is in the dongle and google the name of the chip, this should lead you to a driver which you can use through CE although you may have to reconfigure the 3 dongle..
Jan 14, 2010 | Computers & Internet
Ip connection problem
do a reset to factory settings first.
then make sure, you have dhcp enabled in your computers network settings.
is 192.168.1.1 given in the manual? if not, or you dont have any manual, try 192.168.0.1 or 192.168.2.1, too.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
288 people viewed this question
Top Draytek Computers & Internet Experts
Ekse
Alun Cox
Are you a Draytek Computer and Internet Expert? Answer questions, earn points and help others
