Question about Tomtom GO 700 GPS Receiver
Tomtom 700 unit will not advance past picture with finger pointing to screen. reset several times but no change! I did not use unit for 2 mo. and it was completely discharged.
  • ben1737 Sep 30, 2008
    Unit is unreliable at start up. Most times it will not advance past the screen with road and finger pointing
    Novelist:
  • 158 Answers
It's likely you have corrupted data or files on your SD card. I won't ask if you made a backup .
Please note . ALL SAT NAV owners . Make a backup of your storage media, be it SD card or similar . DO IT NOW !
Posted on Sep 15, 2008
You might want to try:
-- plug to the electrical charger, reset for 15+ secs
-- connect to the computer, download Tomtom app and try updating the application
I had a 2006 purchased go 700 and did the above and it is working much better with latest application.
Posted on Aug 15, 2008
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
TomTom Boot up problem
i think u need to upgrade the software
Jun 09, 2008 | Tomtom GO 700 GPS Receiver
Tomtom 700 dead
After checking around around the web it seems that you are not the only one to get the green screen of death. My suggestion is to hold reset for several seconds, release reset and hold the power button button for 10 seconds. If this doesn't work the only other option is to let the unit sit for several days to let the internal battery completly drain, once drained theirs a good chance it will function normally, this allows any temporary memory to be cleared. Good Luck & hope this helps L8R
Sep 18, 2007 | Tomtom GO 700 GPS Receiver
TomTom go 700 flashing cross at start up
U need just one original file from zour tomtom and that is ttgo.bif so keep that file safe and copy everything from working unit (even better with patched system) to your unit, !!!!! dont use TomTom Home !!!! just through drive (if its not there cant help), just possible that u need now maps activated for your unit, u can find info how to this anywhere,
Jan 25, 2009 | Tomtom GO 700 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 700 will not fully load
On the bottom of the TomTom there is a tiny hole that you stick a small paper clip into. This is a reset button. Its almost not visable you really have to look for it. I have the same problem but I hit the reset and it fixed the problem. This reset won't change or hurt any of your settings it just resets the hard drive.
Feb 13, 2008 | Tomtom GO 700 GPS Receiver
Lcd screen do not light up
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 14, 2007 | Tomtom GO 700 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
80 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
