Question about Zebra P210i Thermal Printer
Eltron P210i printhead replacement and aligment
I changed the printhead but I hae this white space all in the top f the card and don't know how to align. In all series I had a PTOOL software from ZEBRA which help me to calibrate sensors and determine if it was a software or technical problem. I do not find any technical manual or reference about this. Can you help me?
    Scholar:
  • 115 Answers
Can you go into printer properties for the Eltron?
Select Prefrences then Device settings - tools.
You can set the offsets for the axis's.
You can also send direct commands.
+OFP Command - Adjust X-Axis Patch Offset
Description Establishes X-Axis patch positioning setup
NOTE: See !OFP Command for check of current offset.
Syntax
<Esc># 1 +OFP p1 p2
Parameters p1 = Patch Selection
Where:
0 = upper
1 = lower
p2 = Offset
Where:
Range = 100~800
Posted on Nov 24, 2008
  • Zebra Master
  • 2,794 Answers
Usually with Eltron and Zebra printers all you have to do is turn the power off, change the print head, turn the power back on and re run your software to get the forms to reload. If you miss any of these steps you will run into trouble.
As long as the labels didn't get moved, it should work once you restart your computer and re run the software you print your labels with.
Posted on Aug 12, 2008
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at www.DiscountIDStore.com
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
Zebra p330i
lose the two screws from the front plate, put a card under the printhead, ajust the plate on tope of the card, tie the screws. send a command !SA from the driver, and print a test card (send IM command)
Jun 21, 2010 | Zebra Eltron P330i Card Printer
Zebra P210i Win7 Driver
Please take note P210 is not supported on Windows 7 yet at the moment.
Best regards
Mar 09, 2010 | Zebra P210i Thermal Card Printer
How do I replace the printhead on a Zebra P330i card printer
If there is a problem with the printhead you have to send it back to Zebra for repair. The zebra website has info on how to send back printers for service.
Dec 02, 2009 | Zebra Eltron P330i Card Printer
I change the color ink an now it keep saying i have a aligment problems an its not the paper an when i aligment it the black ink dont show up on the paper
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Lexmark All-in-One Printer with PictBridge
Problem with zebra p420i
Go in to control panel,
Printers. RT Click On p210i,
Properties, Device Settings Tools.
Send this Command using the Direct Commant
input Box. Just the First line..
1 +LC 0
Not This--
0
= Counter Value
Dec 16, 2008 | Zebra P210i Thermal Printer
Printer not printer well
Hi:
Check if ribbon is placed correctly, a lot of cheap pvc cards are low quality and have distortion on the faces, you can check them by seeing reflection light al the sides, if misprinted area have a constant pattern the check rollers, if lines appear in the printed cards in the same place a long the card then the printhead is damaged.
Regards
Sep 21, 2008 | Zebra Eltron P330i Card Printer
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Zebra P210i Thermal Printer Logo
219 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
