Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Solution replacement tank
I need a new solution tank for my agility steam vac, it seems the gasket on the bottom is missing thus I can't fill the solution tank up. Were can I get this part or gasket.
Spencer
  • 24 Answers
Visit www.stevessewandvac.com you may not see it on the web but call or contact by email and someone will be able to ship ou the part as wel as answer any questions you may have.
Posted on Aug 12, 2008
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
Jun 19, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I need the schematic diagram for a Hoover Agility F6215-900 steam vac in order to replace the lower recovery duct hose
You will find this URL of help:
http://www.ereplacementparts.com/search_result.php
Please provide a Thumbs Up if you find this solution helpful.
Paul
Oct 04, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I can't seem to find the direction guide for my Hoover F6213-900 Steam Vac PowerMax TurboPOWER
It's on the Hoover website, I just looked it up.
www.hoover.com F6213900
Let me know if you need anything else.
Feb 01, 2009 | Hoover F6213-900 SteamVac Agility...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Leaking out of hole
That is the valve asm. to release the water when it is depressed when you squeeze the trigger. Best to replace it, usually it comes with a new seal, hard insert, spring and valve. Check under neath the seal to make sure that the tank is ok, if a hole or crack, then replace the tank.
Apr 27, 2008 | Vacuums
Water drains out the bottom of cleaner as soon as tank is attached.
You don't say where the water is leaking from i.e. the back or the front. It likely is coming from the back. There is a connection to the "seat" that the tank sits in. There is a small hose that delivers the solution from the tank to the pump in the machine and I have seen them break off at the valve under the handle. If this is the case, the valve will have to be replaced.
Feb 10, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
