Question about Dell 942 All-In-One InkJet Printer
Paper Jam Printer is saying I have a paper jam and there is no paper in there. I have shut down the printer and the computer both to restart them and Im still getting the same message. There have been prior problems with the printer. When I want to print things, the paper does got through on its own, I have had to guide it in so it 'catches' to go through on its own. Im not sure if this is part of the problem. Maybe if there is a roller or something going bad it is reading that there is paper stuck in there? I dont know, help!
I had the same problem and fixed it!!!
What you need to do is to dismantle the printer. Remove the outer coverings but I think all you need to do is remove the cover by unscrewing it and the plastic cover under it. You also need to unplug the wires connecting the scanner and now the top is completely uncovered. Look into the slot where you put the paper and and near to the left with the back of the printer facing you is probably a lever that's been pulled down. Its a small black flat lever so flip it back up and the paper jam should be fixed. Good luck.
Posted on Aug 18, 2008
Nothing says you took the paper out and started over again, putting it in slowly so as to go in evenly.
MAYbe this will work. GOOD LUCK
Posted on Aug 17, 2008
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Paper jam
try to check it again maybe there is a small piece left inside the printer or you can try to restart your computer and turn off your printer then during the restart process practically the BIOS booting start your printer.
Jun 19, 2009 | Canon PIXMA MP470 All-in-One Printer
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
qwester
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Paper Jam
Check carefully, maybe you have just small peace of paper on the sensor actuator.I suggest to inspect whole path of paper.
Feed,transport,fuser.
Nov 02, 2007 | Dell 3000cn Color Laser Printer
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
Dell 942 All-In-One InkJet Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
