Question about LG enV VX9900 Cellular Phone
External display stays lit when charging
I have set the display settings for charging to "off" but my external screen remains on as long as the phone is turned on and plugged in. I'm afraid it will burn out the screen.
  • 3 Answers
Don't worry everyone's env does that and nobodies screen has burnt out yet and if it does which is highly unlikely verizon or LG will have to fix it.
Posted on Aug 15, 2008
Nokia N95 screen stays lit and won't turn off
in your phone the belt of your display are not properly set in connecter , u pls open your phone and display belt are set again that solved your problem
Mar 05, 2010 | Nokia N95 Cellular Phone
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
You have the option to change it under display settings in ur main options menu. menu>system settings>display settings>front screen(?)>desplay timmer. This should do the trick. I have mine on 10 seconds and that works great. I hope this helps.
  `Nbryson
May 27, 2009 | Motorola Mobility W510 Mobile Phone
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
It will not let me change the external wallpaper, internal yes, external always shortcut menu
Go to Settings->Phone Settings->Set Shortcut Keys->External Shortcuts->Display->Off. Then you will have a wallpaper and just touch the screen to see your shortcuts.
Mar 04, 2009 | LG VOYAGER VX10000 Cellular Phone
External display doesn't work anymore
The LCD needs to be replaced, take the phone to a mobile repair center and have them replaced it for you.
Aug 18, 2008 | Motorola Mobility RAZR V3
External display will not shut off
from settings find the option of screen display, find the choice for screen back light, and change the time to 3 seconds or 5. It is in there just browse thru your setting for screen dislay.
Artgirl
Jul 18, 2008 | Motorola Mobility RAZR V3
I880 External Display
go to main menu then to settings push ok push ok on display/info
push ok on wallpaper can you see it now
Nov 05, 2007 | Motorola Mobility i880 Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
External Display Help
Hi There, If u r external display has a line through this could be the result of a few things... 1. your phone fell 2. you may have got a faulty phone if it is new or even used. to solve this problem u need to have the external screen replaced by a qualified phone repair personel.Hope this helps. Sam !
Jun 30, 2007 | Motorola Mobility RAZR V3
LG enV VX9900 Cellular Phone Logo
117 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
