Question about Cyberhome CH-DVD 300 DVD Player
Region error message
I don t know what my grandson did but now it is saying region error for my dvd which is a region1. I have tried several other DVDs but am getting the same error message. What can I do to fix it?
  • prptoni Aug 13, 2008
    Thanks, that fixed it
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are the DVDs you are playing set for region 1?
  • Cyberhome Master
  • 2,794 Answers
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Next press open/close. Put in your movie and enjoy.
Posted on Aug 12, 2008
Hi i have a lg bg550 blueray dvd and i have just got a region1 disc is there a unlocking code for this model so i can play region1 and region 2 discs regards **** towner
Could not locate this model but this may help:
Power up the Player, press pause;
Type in 314159 on your Remote Control's Keypad;
This should bring up the Region Selection Screen;
Select the Region (1-6) that you wish to view on your Remote Control's Keypad, sit back, and enjoy ;-)
Two important features with this player.
Firstly, in addition to the first hack listed above, instead of choosing a Region 1 through 6, you can choose to set it Region 0, or region free. This means you will not need to change it every time you put in a disc of differing regions.
Also, if your TV is not capable of both NTSC and PAL playback, you can adjust the format of the DVD player signal by flicking the System Select switch on the rear of the player. Without changing this, the region free hacks listed above may not display correctly if you are using an older TV
To enable VCD, it works for this model as other LG players:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the
characters 01 47 should appear on the display) [If your player is a non UK
model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the
display)
[This number may be different depending on the configuration of your
specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be
displayed).
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
http://www.videohelp.com/dvdhacks/lg-5500n/4153
Jul 25, 2011 | LG BD550 Blu-Ray Player
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Jan 01, 2010 | Insignia Televison & Video
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Cannot Play Commercially Produced DVDs (Panasonic DMR-ES40V)
Dear FixYa Team,
Thanks for your inquiry re my problem.
Since I posted, I THINK I may have solved my problem. I unplugged the unit for an hour or so, plugged it in again, and it DID play a "commercial" DVD that I had tried earlier. I don't know if this is a permanent solution -- we'll see. If not, I'll take the next step in seeking some help.
Thanks again.
Sep 13, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Disc Region eror
you may have a different region on you dvd to your dvd player. say your dvd player was 1st region you can only play 1st region dvds if you try a 2nd or 3rd region dvd it would not work. you can go to a dvd specialist to get it tuned to a multiregion dvd player.
go to a dvd player shop and ask if they know how to tune it.
Jun 27, 2008 | 2007 GMC Sierra Classic Denali
DVD region playback error
Went into the settings menu, searched for the 'default' tab and reset setting to default & hey presto....all ok!!
Simple when you know how!!
Apr 21, 2008 | DMTech Televison & Video
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
DVD REGION CODE FIXED TO WRONG REGION
You can only do 5 resets of this for the life of the DVD drive.
Instead of resetting it, consider buying a piece of software that lets you disregard region settings, such as AnyDVD (google for it).
Dec 18, 2007 | Compaq Presario Notebook
Cyberhome CH-DVD 300 DVD Player Logo
97 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
