Question about Whirlpool LGQ9858PG Gas Dryer
Heating element doesn't work right now
No clog in lint area. No blockage in vents. What to do?
  • 943 Answers
Hi thanks for the question. All gas dryers have a thermal fuse . the first part to fail, with dirty venting ,clogged up kinked, pushed up to close to the back wall. the thermal fuse is located on the air duct close to the venting inside locate . its a small plastic piece with 2 blue wires to it replace thispart. thanks the appliance doc
Posted on Sep 30, 2008
Dryer is putting hot air in the Landry room
Most likely your vent is clogged and check for clogged vent and heating element and clean lint filter housing with vacuum
Dec 09, 2013 | Samsung White 7.4 Super Capacity Electric...
Beko wma 1512s not heating up and ive replaced element still not working?
possibly bad gas valve or your venting is clogged with lint.go on the outside of your house and make sure the air is blowing out strong
Nov 09, 2013 | Washing Machines
It takes about 3 hours for my clothes and towels to dry this is getting ridiculous, any ideas thanks
Hello there and welcome to fixya
This is a very common issue with most makes of dryers here is a few things that are the most common problems
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. i will post a picture of the parts on the back so you can look at them too ok?
Sep 24, 2011 | Maytag Performa PAV2200
MY DRYER ISN'T HEATING UP. CAN IT BE LINT STUCK SOMEWHERE?
yes a lot of times the dryer vent gets clogged up and the unit cant breathe and the heat elements are cut off by a safety overheat switch or someone couldve pushed he dryer back too far and kinked the hose take the dryer vent off of the dyer and pull it away from the wall and dry a load of clothes if it starts drying u may have a clogged dryer vent or u had he dryer vent kinkedif that doesnt remedy the problem then more than likely u have one of ur overheat sensors gone out u have to take the wires off of them and check for continuity thru them they are usually on the back on the element housing and the blower housing and round take the wires off of them and check for continuity
Feb 25, 2010 | Washing Machines
Kenmore he3 dryer check lint screen flashes and dryer wont start. Yes checked lint screen
Hi
Try unplugging it or turning off the power at the breaker panel. This should reset the controls.
Weather this works or not, make sure that the whole dryer vent is clear. often we find a clog in the flexible line, or where the duct exits the house. also there are situations where the clogged duct caused a lint plug inside the dryer. Assuming you can reset the controls, you can run the dryer for a minute with the hose unhooked to see if you are venting the right amount of air.
OR
It is possible the heating element has gone out or one of the thermal disk has blown its fuse. If you turn the dryer on holding the button that is depressed when the door is closed so that the dryer will run you should be able to see if the heating element is getting hot because it should show as a red glow. If this is not happening then most more than likely the heating element has gone out. Most of the time they are fairly easy to replace.
OR
a simple thing is that When the lights are flashing, it is an error code, which indicates a problem with the door switch. Could be a loose connection there.
Thanks for contacting fixya.com
Nov 20, 2009 | Kenmore Washing Machines
The lint trap on my dryer is extremely hard to empty the lint sticks to it so bad I have to use a brush to get it out. It seems like it gets too much moisture in it. Is there an easy solution?
If your electric dryer is developing retaining moisture inside the dryer vent, then you have a clog in the exhaust vent ducting somewhere. The moisture comes from condensation inside the dryer exhaust. As your clothes dry, warm moist air is exhausted out the dryer exhaust vent ducting. If you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. Once the lint accumulates, it begins to collect moisture. As it collects moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becoimes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope you find this information helpful.
Nov 14, 2009 | Washing Machines
It takes three cycles to dry clothes, andthere is heat?
The most likely cause is poor airflow. This may be due to a clogged lint screen (should be cleaned after each load) or a clogged vent. Run the dryer empty and feel the airflow from the vent outlet (where the vent exits the house). If there isn't a good strong flow of air, remove the duct where it attaches to the dryer and check for flow right at the dryer. If there still isn't good flow you may have a bad blower, but chances are the duct is clogged with lint. If it's the white plastic flexible duct or the corrugated metal kind you should replace it with solid 4-inch vent pipe. This will give the best airflow and the smooth walls won't promote lint buildup.
Jan 26, 2009 | Kenmore 22422 Top Load Washer
Heats but won't dry
I'm not at all familiar with the Malber brand, but I do know that the basics any dryer needs to work are: 1. Heat 2. tumbling (so the air can reach all areas of the wet clothes) and 3. air flow, so the moist air is removed from the dryer.
The number one cause of poor or no drying is poor air flow. Check the end of the vent outside to see if you are getting a strong flow of air out when the dryer is running. I'll bet you are not. Find out why and correct. (clean out lint, reduce or better yet eliminate any flex duct, try to make vent pipe as short and straight as possible, use a dryer vent end cap which has a large opening, etc.)
Nov 02, 2008 | Malber WD1000 Front Load Washer/Dryer
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Lint Blows Out the Top!
Lint backing up into a dryer is generally caused by improper air flow, which is caused (generally) by clogged ducting. If you say your ducting is flowing freely then you may still have a partial back up somewhere inside the dryer. Usually the blower fan area and/or the lint screen duct leading into the fan area can build up with packed lint. If you're not appliance savvy, dryers can sometimes be tricky to get inside. I recommend using a long lint brush to access those hard to reach areas of your dryer. To answer your other question, the ducting should be as straight as possible. Bends and kinks are often areas where lint will start to build up and eventually clog. The first sign that you're having dryer vent problems will be longer dry times on your clothes. I hope this will help.
Apr 19, 2007 | Whirlpool LER5636PT Electric Dryer BISCUIT...
Whirlpool LGQ9858PG Gas Dryer Logo
62 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
