Question about Electrical Supplies
Sears Craftsman Cordless Screwdriver Model 315111820 lost torque
When replacing the batteries, the chuck assembly fell out of the housing. After replacing it the way I thought it was, the torque is much less and will not start a screw. I think it has something to do with the placement of two silver washers which I currently have together directly in front of the motor. Does anyone know the exact positioning of these two silver rings? I tried the Sears site and they no longer have any info on this model. Thanks.
djpaulwb@hotmail.com
  • 313 Answers
SOURCE: ryobi skilsaw housing assembly+Ryobi Flashlight Bulb
see www.ereplacementparts.com for ryobi breakdown & cost of the parts
Posted on Jul 26, 2008
  • 313 Answers
SOURCE: Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Posted on Aug 19, 2008
  • 35 Answers
SOURCE: need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Posted on Nov 21, 2008
SOURCE: sears keyless pad
hello - we have a craftsman model 139.53684 and these are the instructions for setting the personal entry code - (you will need two people doing this) To set the code using the Premium control console: 1 Enter a four digit personal ID # of your choice on the keypad then press and hold ENTER. 2 While holding the ENTER button, press and hold the LIGHT button on the premium control console (the premium control console is the main opener button mounted in the garage probably near your door) 3 Continue holding the ENTER and LIGHT buttons while you press the pushbar on the premium control console (now all theses buttons are held) 4 When the motor units lights blink Release buttons - it has learned the new code. If bulbs are not installed you will hear two clicks. To set the code using the 'LEARN' button (you will need a ladder & two people doing this) you used the learn button to set the new remote. 1 press and release the learn button on the motor. The learn indicator light will glow steadily for 30 seconds 2 within 30 seconds enter a four digit personal ID number of your choice ob the keypad then press and hold the ENTER button 3 Release the button when the motor unit lights blink If bulbs are not installed you will hear two clicks. I hope this fixes your problem - please post & let me know - thanks Sam
Posted on Dec 11, 2008
rowdy45176
  • 2176 Answers
SOURCE: how do I replace battery in Black and Decker cordless screwdriver
Just to clarify you have a model number 9076 and I would assume type 1. If so there are screws holding the 2 halves together that would have to be removed the batterys are in the lower section of tool. They are about 8.60. I would recommend going to DeWaltservicenet.com and typing in your model number to look at a product explosion before attempting this repair. Keep in mind that I saw that quite a few of the parts are no longer available so it might be time to retire this one.
Posted on Jan 01, 2009
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
My Craftsman cordless screwdriver doesn't charge
you have a short in the battery or charger,,,very dangerous ,,the batt could explode
Jul 27, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Don't know how to get the various attachments on and off the tool
it is a chuck...of sorts. There should be a button to lock the shaft and then you can use the wrench it came with to loosen it.
Apr 21, 2010 | Craftsman 2.0 amp Rotary Tool Kit
Spindle fell off, what holds it on 13 inch 2/3 speed. sears craftsman
by spindle I assume you are talking about the chuck and the shaft that is in it, if so what you need to do is use something like brake clean and thoroughly clean the shaft and internal socket. Wipe both dry with a paper towel. Move the table out of the way and find a block of wood and a hammer. retract the chuck jaws fully and place the block of wood on the face of the chuck and HIT it with the hammer a couple times. This is a taper socket fit and that will seat it. If other than that I would need the tool catalog number and I will find a schematic and try and help.
Mar 22, 2010 | Craftsman Drills
Removing chuck from Sears 8
Ours was a press on,I used a wedge between the chuck and the shaft housing.Couple of hits and it came right off.It's a tapered shaft,we used a dead blow hammer to tap the new one back on.Haven't had a problem sense!
Jan 12, 2010 | Garden
Looking for charger no.7228201 for craftsman 4.8 volt cordless screwdriver.
those unit were made for sears check there web site. the part number my tell you MFG of the unit. if not you'll have to buy it from sears
Oct 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
The chain has come off the sprocket.
The gear/sprocket assembly needs to be replaced with part # 41C4220A. The top bushing is worn out that is why the chain fell off.
Dec 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
I need to replace the starter rope on my Sears Craftsman edger. I cannot determine how to take apart the starter housing assembly. Model is a Sears Craftsman Edger Model 536.797470 Thank-you
it should be a shroud its all in 1 unit it should have 3 bolts holding it to the engine block un bolt the shroud & e-mail me or call me i will help you get a string in so you can use my name is wade 831-578-4034 if i may help ya
Jun 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Electrical Supplies Logo
155 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
