Question about Samsung HCL5515W 55" Rear Projection Television
Fuse solution I actually thought of that, but am waiting for the manual to FIND the fuse, can you point me in the right direction?
    Master:
  • 623 Answers
Its usually near the power cables
Posted on Aug 12, 2008
I have a 89 f250 2wd none of the gauges work on the cluster. Lights work fine but no gauges. Can someone point me in right direction. I replaced cluster and still nothing.
There is a fuse for the cluster gauges. Ford stinks because if you don't have the manual, you can't find the fuse. I pull all the fuses and look at them. This tells you they are good and gets rid of any corrosion problems. After this you will have to find the fuse and check the wire from the fuse to the cluster. You will need wiring diagrams also.
May 05, 2016 | Cars & Trucks
What would cause 30 amp auxilary fuse to blow
that's a heavy short. What are the auxiliaries? could be the cigarette lighters or other optional devices. There is likey a major bad part or direct shorting wire (cut insulation) (Loose wire touching ground). Look first at the cover or in the manual to point you in the right direction. if none then look near and behind every cigarette lighter connection in the vehicle. Just last week I stacked some of these up wondering why I had them since I have never had a short take one out....
Sep 10, 2015 | Cars & Trucks
Back up alarm, and lighters dont work now . where are the fuses ?
There are 2 fuse boxes / fuse panels in nearly every Ford product: one directly above the driver's left foot (when the driver is actually sitting in the driver's seat). The other is inside the engine compartment, on the right side - contains high current fuses.
There is extensive coverage of fuses and the circuits each one protects Owners Manual.
Good luck
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 21, 2010 | 2000 Ford Windstar
Need location of fuse for cruise control 1998 ford escort zx2
Inside the fusebox cover is a small white plastic tool for pulling fuses out.
Inspect the center section of the fuse to determine if it has 'blown' - it will be obvious if the metal strip has melted.
Insert a replacement fuse of the same color / amperage protection by simply pressing it into the fuse-slot. Also if you look in the owners manual there is a diagram to help you.
If you need further assistance please let me know thanks, Midwest-tek
Aug 31, 2010 | 1998 Ford Escort
Locating the fuse box
Check the Ford-Taurus-Owners-Manual for this location and fuse description.
Hope helps; remember coment and rated this.
Aug 05, 2010 | 2000 Ford Taurus
Need to know where the windshield wipers fuse is located
The Owners Manuals have detailed illustrations and information regarding the two fuse box / panels, and the various vehicle systems each fuse connects to.
Jan 30, 2010 | 2009 Ford Taurus
Where is the driver side power window fuse in Feroza II
Check out www.warfs.org. You can download all of the work shop manuals in pdf format (no charge) including the electrical wiring and fuse locations. Sorry, I don't have power windows in mine so I can't point you in the right direction from first hand knowledge. I hope this helps.
Dec 01, 2009 | 1991 Daihatsu Rocky
Location of fuse box
Nov 20, 2009 | 1998 Ford Windstar
Where is the fuse or relay for the heater or a\c
Jul 26, 2009 | Ford Windstar Cars & Trucks
Samsung HCL5515W 55" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
