Question about Minolta magicolor 2300W Laser Printer
How do I change black toner? Blue is accessible but how do I get it to rotate?
Toner
  • wlb007 Jan 26, 2009
    The printer does not print anymore when a document command is sent to it. The display panel says low Yellow toner cartridge . BUT I cannot change the yellow toner cartridge because I do not know how to rotate the cartidge from its present postion to the position it needs to be to be removed from the housing. Please help,
    Thanks
    wes
I have opened and closed the front door a number of times so that the cartridges rotate to different positions. It's trial and error until the right color is in the position to be changed.
Posted on Dec 02, 2008
You have to use the menu to select which cartridge to change. It will then rotate the drum and say "open door" to replace the cartridge.
Key is, use the menu to select which one to change and the printer rotates to the correct toner.
Posted on Apr 03, 2009
How do you change out the black toner?
If you can not rotate the toners by using the DISPLAY MENU,
You can rotate them MANUALLY, using a flat head screwdriver or even a key for your car or front door.
Open Front Cover/Door of Printer
Remove Waste Toner Box
Where you see the side of the Blue Cartridge, look to the LEFT and locate a small rectangle with a circle inside it.
Push your car key or flat head screwdriver into this rectangle and the circle will push back and release the lock on the cartridge, holding in with one hand and turning cartridge with the other hand until you get the cartridge you want to replace.
Remove the screwdriver / car key and pull out the empty cartridge and replace with new one.
Replace Waste Toner Box, close front cover/door, switch on and the printer will rotate back itself to it's normally position...... JOB DONE
Jan 19, 2010 | Minolta magicolor 2300W Laser Printer
How do i manually rotate cartridge carosel
You don't want to rotate the toner cartridges, you need to get a new Drum Cartridge assembly.
When you get that, it will have detailed directions, but you'll end up opening the top of the printer and pulling the drum straight up.
This is a different component than a toner cartridge. The toner carts are the supply of new toner. The drum cart collects excess toner during the printing process, and when it's full you need to get a new (empty) one.
If you connect to your printer's web interface it will have a link for "order supplies" that will take you right to the dell.com page for it.
Post a comment back if you need me to get the URL, and I'll grab it from my printer when I get home tonight.
Sep 02, 2009 | Dell 3010cn Laser Printer
Trying to change black toner on KM2300DL
Some units have a rotating drum system and will not present the cartridge for replacement until  the device asks for the new toner cart.
May 06, 2009 | Konica Minolta magicolor 2300DL Laser...
Rotating toner cartridges to change
Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
Apr 08, 2009 | Canon Office Equipment & Supplies
Blue marks on epson c1100 colour printer
It is likely that you had a cyan toner spill, the spilled toner collects in a tray beneath the toner carousel. You need a toner vacuum with a long thin nozzle. Remove one of the toners to gain better access, if you remove the PCU also you can rotate the carousel from the top as long as the front cover is shut. Vacuum up any loose toner from beneath the carousel, the mag developer rollers can be vacuumed from above and recharge the toners by rotating the white plastic gears at the ends of the rollers. Don't use an ordinary vacuum as the toner is very fine and may damage it.
Mar 13, 2009 | Epson Office Equipment & Supplies
Smasung clp 300 will not print in blk
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Mar 07, 2009 | Samsung CLP 300 Laser Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Black Toner Cartridge
Open the front door, look to the left for the interlock, insert a screw driver or similar into lock.
Carousel can now be rotated by hand.
I believe you can also rotate the carousel to a particular toner via the panel and driver.
Apr 09, 2008 | Epson Aculaser C1100 Printer
Minolta magicolor 2300W Laser Printer Logo
295 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
