Question about Dell Inspiron E1505 Notebook
Screen is black
Help, Laptop screen is black, no light at all. Powers up, WIFI light is on, battery lights is good, sounds like it is loading up but there is just a black screen. Of course it is out of warranty and Dell will not even speak to me.
Any ideas. Thanks
    Genius:
  • 2,028 Answers
When you say sounds like it starting up, can you hear the Windows sound byte, or just the hard drive spinning and CD drive engaging?
Posted on Aug 12, 2008
SOURCE:
Light bulb icon lite up blue and black screen
Remove main battery and power up, no change! sub out the memory ram one at a time and test each piece, if still no change! laptop will need to be checked.
Apr 10, 2012 | Acer Aspire 1200X Notebook
My laptop sounds like it's running but the screen is black and the green power light and the blue wifi light is on. If I disconnect the battery it sounds light it's off but the green and blue...
If the screen is black but it's making all the right sounds that you'd normally get when the computer was working, then you can, in all likelihood, connect the NC8000 to an external monitor, do a cold start, and work off an external monitor for now. And you have also isolated the problem to be "up top" (the screen area)
If it just turns on but outputs nothing to the LCD or the external monitor, then it's probably trouble. I'd remove the memory and reseat them. If that doesn't make a difference, then you'll have isolated the problem to be "down below" (the motherboard, in all likelihood).
Hope that makes sense...
Sep 05, 2011 | HP Compaq nc8000 Notebook
When I power up laptop blue power light and hard drive light for 10 secs but then powers off completely. the laptop will not start at all it's like its shorten out. tried with battery out and just the...
Remove the battery and hard drive and the ram chip/s. That just leaves the Processor and mains power input running. The laptop should make beep sounds to indicate there is a ram problem. If it does not then you will have to open the laptop up and remove the internal battery for 10 mins and refit. See if that works. If so then go into the bios and load Optimised defaults and input the date and time. If that does work then the motherboard has had it.
Jul 31, 2017 | Toshiba Satellite A100 A105 Series Laptop...
Hi, I have a HP Persario CQ60 Laptop. W hen i switch it on, the power putton and wifi light up, the little power light turns on and i hear the CD rom drive for a couple of seconds but nothng else hhappens...
mines does the same but wen u here it start up an the screen goes blank take the battery out then it will say start windows normaly or safe and safe made networking click on safe mode networking and u can use your laptop again but with no sound hope this helped
Nov 18, 2010 | Compaq Presario CQ60-220US PC Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My 26" LCD tv has black screen When I was watching it screen went black unplug ova nite still Same thing barely see movement IN back Ground up really close so but it have sound But black screen can...
Good day!
LCD screens have very thin fluorescent light tubes. if you can barely make out an image its most likely that the Power inverter board that powers the lights is damaged.
Aug 24, 2010 | Televison & Video
Compaq CQ50 laptop powers on, but does not boot. Black Screen Lights on keyboard, lights on power jack port. White power light is on the power button. Fan Runs and the DVD runs but no response from DVD. No...
I'd try messing with the memory. Try booting one single stick in each of the slots.
I've noticed that this happens pretty frequently with certain hp / compaq models.
If you've already tried that you can try removing the cmos battery for 5 minutes but aside from that the motherboard has probably gone out :(
I hope it's under warranty!
Nov 20, 2009 | Compaq Presario CQ50-215NR Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Dell Inspiron E1505 Notebook Logo
200 people viewed this question
Ekse
Clive
Clive
