Question about Navman F20 GPS Receiver
When I try to update my navman It says I'm not connected and I am?
I am trying to update my navman f series and I run the program and my pc tells my that the navman is not connected, to plug it in and turn it on. Well its plugged in and turned on to the usb streaming screen. what am I doing wrong? is it a driver thing?
  • 1 more comment
  • fred0000 Aug 13, 2008
    when I try to update my navman It says I'm not connected
  • Anonymous Aug 27, 2008
  • peter86b Feb 28, 2009
    mine has the same problem, I even tried different usb's on my pc & still no joy. aparently once you update it, it starts messing you about anyway, so i think I might leave it the way it is!
Hi - yes it probably is a driver thing. Navman's install software apparently doesn't install the Windows driver - you have to do it manually.
I just found this how-to page on Navman's website, and it worked for me:
http://www.support.navman-europe.com/FAQs/Drivers/F-Series/
Good luck
Peter
Posted on Oct 31, 2009
I have connected my navman to my computer to install the updates. I am not sure if it is doing it as no prompts appeared on my screen. On the Navman I see a computer and the Navman and the connection. ...
Assuming you have NavDesk already installed on your computer, you have to open the NavDesk software/program. Once the software recognize the device, you will be prompted if an update is available. Then follow the prompt to update the map/application.
Mar 03, 2014 | GPS
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Jul 06, 2008 | Navman GPS
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
My software is 2008. How can i download the latest software for navman s75?
Please follow this link for North America: http://www.navman.com/in-car/North-America/USA/Customer-Support/6296/
Please follow this link for UK: http://www.navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
Select "Download Software Update 145MB" under Select S-Series Software Update (SP2)
*Note: this only downloads the software update not a map update. For the latest maps or safety camera subscriptions please visit the Navman Store. You will have to pay to update your map.
Mar 02, 2011 | Navman e Series GPS Receiver
How do i find out what maps are on my navman, had a canadian map but cant seem to find it
The smart ST software you should installed on your pc should tell you what maps you have, just run the program connect the unit to the pc and it will tell you
Jan 03, 2010 | GPS
Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
Sep 17, 2009 | Navman NavPix N40i GPS Receiver
B2+ software update
Hi The B2 is not the device that requires ID updating but the navman F series module, as this is what actually displays the Caller ID. Go to the address at the end i've given you and it'll take to straight to the relevent download page and download your relevent F series download. http://www.navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
Feb 21, 2009 | Navman F20 GPS Receiver
Reset navman F10 sat nav
Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
Sep 23, 2008 | GPS
Navman f20 & b2 series handsfree
I downloaded sp2 update for f20 from navman and it upgraded my navman to 4.10.1028 but still cant get caller id
Dave
Jul 23, 2008 | Navman F20 GPS Receiver
What does the CD look like I think I have it, but it does not run for f20
Go to their website:
you can buy updates such as traffic info subscription from the Navman website. This on is for UK. Choose your region 1st.
http://www.navman.com/Navman/Templates/standardcontent____4407.aspx
Apr 05, 2008 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
992 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
