Question about Dometic Rooftop RV Air Conditioner
Kamper2@earthlink.net has more info as requested
We did as requested and used a stop watch and pencil to record our Dometic unit's cycle. We found that the compressor will only run 9-10 minutes and then shuts off, only to restart in 2-3 minutes regardess of inside temp. We timed this over a14 hour period and the only time it shut off properly was late at night when it had finally reached the temperature set on the comfort control center. During the heat of the day, the fan ran for 53 seconds after the compressor shut off, then all would shut down only to restart within 2-3 minutes. This was consistent for hours without our intervention whatsoever. Finally, the compressor and fan started shutting down at the same time late that night. next morning, it took the temp to rise in the rig to a total of almost 5 degrees above the set temp for it to cut on and then it began it's cycle of 9-10 minutes compressor time and then starting up again 3 minutes later. I assume that this afternoon, when it gets hot again, the compressor will still be cutting off every 10 minutes but the fan will start going into high gear for the 53 seconds. What's the deal? Shouldn't the unit stay on until it reaches the set temp? I am not asking it to go 20 degrees below the outside temp. I am setting it to 73 degrees with it being only 83 degrees outside. Yet, because it keeps cutting on/off, it is taking it forever to get to the set temp! Not to mention the fan kicking into high gear during the hottest part of the day. We have extended warranty and want to get this fixed but the last serviceman didn't see it acting up and didn't want to replace anything until he knew for sure. We know it is not the amperage and the sensor that clips into the coils was not the problem. We visually know that the coils are not freezing up. Please help!
Hello kamper2 - Sorry for the delay in answering. I had a response prepaired but something cleared it on me about 2AM last night and I just couldn't think any more. Sounds like your problem is similar but different. I don't think you have to spend any more time on the roof looking at the roof unit. I have been working with a tech and Dometic for over 6 weeks. Right now I am running my A/C on an extension cord out my window and over the the power pedestal for power. The 12 VDC to the A/C circuit board is coming from a car battery sitting on my kitchen floor. The communication cable is a 25' telephone extension cord draped over my kitchen slide over to the CCC. Last week end I turned off all power to the trailer (110VAC and 12VDC) and sat here all day running just the A/C. It shut down 6 times. This was an effort by Dometic to eliminate RF energy affecting the microprocesser on the A/C control circuit board. Apparently the CCC and A/C control circuit board have some idiosyncrasies that aren't well explained. I also have an extended warranty on my A/C with Dometic. I'm thinking they believe RF energy may be picked up via the communication cable and affecting the microprocessor. Do you have a cell phone, wireless router for your computer or telephone or something that may put out noticeable RF energy? If you do, turn it off for a while to see if that may be related to the shut down's. I'm still working on my problem and no solution or reason yet. The circuit board in my A/C has already been replaced. I am assuming you do not have an icing problem with the problem A/C. If for some reason you decide to replace the communication cable from the CCC to the A/C circuit board, be aware that a typical telephone extension cord will not work. You must replace one of the plugs so the wires are straight through (pin for pin) and not reversed as the typical telephone extension cord is. Good luck with your detective work! azbill375
Posted on Aug 13, 2008
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Dometic rm2652. Inside of fresh food section is down to 20 degrees, everything froze
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Since this unit has no compressor and uses an ammonia mix and heat to cool, it isn't your standard household refrigerator. So be careful working around the coils.
The most common failure for your problem description is the thermoster followed closely by the lower control board. But we have also been finding more and more corrosion buildup on the terminals that is keeping the unit from functioning correctly. Suggest you ohm check the thermoster to see if it has opened. If that shows an open, then replace. If that doesn't work, then take the lower control board out and clean the terminals and connectors with a scouring pad following by the #2 pencil eraser cleaning of connectors. If that doesn't correct it, then replace the lower control board.
Sep 11, 2011 | Dometic RM2652 Refrigerator
How to charge spy net watch
"The Spy Net Video Watch will need to be charged via the USB charger that comes with the unit. Although the watch comes with a small charge out of the box, you will definitely want to charge the unit before use. The approximate charge time is a reasonable 2 hours and can be charged via a laptop or home computer. If the watch ever loses its charge, there is no risk of losing any data since it uses a fail-safe memory feature that keeps your data secure and safe. Like most electronic devices, you may see the watch "freeze" from time to time, but you can fix this quickly by holding down the reset button on the side of the watch."
http://www.populartoysforchristmas.org/spy-net-secret-mission-video-watch/
Apr 01, 2011 | Mission Spy Net Secret Mission Video Watch...
I have an unused 4 year old dometic rc4000 portable refridgerator that was checked to be working when purchased but on trying to run on mains electric today does not appear to be working (no sound to...
I HAVE THE SAME PROBLEM THOUGH I HAVE BEEN USING MINE FOR THE PAST 4 YEARS...ON INSPECTION ...REMOVED ALL THE PLASTIC COVER ABOUT 12 SCREWS,...FOUND A YELLOW POWER ON THE PIPES AND IT LOOKS LIKE THE COOLANT HAS LEAKED OUT????
SAVEABAT AT ADELPHIA DOT NET
SAVEABAT@ADELPHIA.NET
JOHN
Aug 27, 2010 | Dometic RM2852 Refrigerator
I need to find a cycling thermostat for a Dometic Roof top unit
I ran across the same problem and found the kit to expensive. I gutted the parts added a transformer, contactor and thermostat. Unit worked great and cost about half the price.
Jan 04, 2010 | Dometic Rooftop RV Air Conditioner
How to I get an operations manual for a Dometic 2620 refrigerator
Here's a link to a site with free manuals for Dometic fridges that you can download for free.
You might have to check some of the other manuals, as one manual can cover multiple models and units.
http://gasrefrigeration.net/dom_techdata/2300_2800OP.PDF
You can get access to the main web page at:
It is a good resource for RV parts and info including troubleshooting tips and guides.
Hope you find this very helpful and best regards!
Jul 19, 2009 | Dometic RM2620 Refrigerator
What is the Price of the Sprint Earthlink Web Cam?
I found this ebay auction for 10+ of the item you are requesting:
http://cgi.ebay.com/Earthlink%2fSprint-USB-Web-Cam-Laptop%2fDesktop-PC-Camera_W0QQitemZ200353956422QQcmdZViewItem
Says $2.99 a piece (plus shipping/handling) It is an old webcam though.
Jun 21, 2009 | Ezonics EZCam Webcam
Need more info
US Branch Address: address02.gif PROTON Corporation
2540 Corporate Place. Suite B111 Monterey Park, CA 91754 U.S.A. No. 63, Sec. 1 San-Ming Rd. Banciao, Taipei-Hsien, Taiwan, R.O.C. Telephone: +886-2-2962-5135 +1-323-980-8292 Fax: +886-2-2954 7316 +1-323-980-8293 Email: info@protonav.com info@protonav.com
best i can do at the moment is to provide you with the american contact information as i do not offer technical support for these devices....
The website is www.protonav.com
Robert
Sep 12, 2008 | Protron PD-DVR100 DVD Recorder
User manual for the classic cdr201recorder
Did you ever find a user manual for the Classic CDR201 Recorder? I haven't used and can't user's manual. I need help please. horizonenter@earthlink.net
May 29, 2008 | Audio Players & Recorders
Recording from guide plus
Recording from the guide requires that the unit be off to receive guide info regularly and copy it to the HD. If your reception is poor or your DVD on time is too great, the guide will not have any info, and the recording be nameless, except for channel and time info. You can force the EPG mode by removing the power plug from the back of the unit, but only do this after you have turned the unit off! While copying the guide to the HD, the display shows EPG while th unit is off, and you will hear the HD cycling.
Jul 19, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Dometic Rooftop RV Air Conditioner Logo
125 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
