Question about Denon DCM-290 5-Disc CD Changer / Player
The tray will not open. I loaded the cd's into the changer, closed the tray and it sounded like one of the cd's may have slipped. It does not change or play.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 95 Answers
My friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
Posted on May 10, 2011
  • jmicchelli May 11, 2011
    The problem actually resolved itself :-) I was going to take the unit to a repair shop. I was carrying it flat with the door facing down and the loose cd slid out. When the unit was powered up the tray opened up and it works fine now.
SOURCE:
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Tip
HARMAN FL8385 CD CHANGER TRAY ALIGNMENT
We've all done it, or one of our youngsters do it for us... knock the multi disc tray out of sync with the drive gears.
With multi disc trays, the CD drive has to move out of the way during disc change and tray loading. Occasionally a disc jams, someone forces the tray movement, and you hear the GRIND, GRIND, GRIND of slipping gears.
Most designs have a switch-hit gear setup that's self correcting for small adjustments but occasionally the mechanism slips beyond self correcting.
Here's the process to open up and fix the tray alignment for Harman's FL8385 CD Changer.
http://www.keepandshare.com/doc/view.php?id=1660661&dn=y
3.7mb PDF.. (I'll try to shrink the filesize later)
on Jan 06, 2010 | Audio Players & Recorders
5 cd changer problem
what brand/model number?
Jan 03, 2013 | Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
CD tray won't open or close on onkyo dx-c606 cd changer.
Yes! it sounds very likely that a small loading belt has stretched, or the loading motor is not working, this is not an easy repair because the gears are timed and synced to work together, if the unit has a loading belt pull tray all the way out and look in the empty tray, may be visable! if you can remove it without taking it apart all the better, have a Tv repair shop size up the belt for replacement.
May 01, 2012 | Onkyo Audio Players & Recorders
Cd changer tray wont open
Hello
There is some mechanical trouble with the tray loading mechanism. you must ahve thorough knoledge and experience in repairing changer mechanisms. Unlike individual disc mechanisms, changers will have more alignment points and gear wheels. Moreover, there will be spring, which will have high strength. As you try to open the mechanism, the spring will slip out. It is a very hard job for an unexperienced person to refit this spring in position. OK.
Dec 27, 2011 | Audio Players & Recorders
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Cd tray wont close, cds wont play
Sounds like you probably have a stretched belt on the load motor. Unplug the unit and remove the case which will expose the load motor. Plug in and turn on and press tray in button. You should hear the motor run and if you can see the belt you should see it slipping. Some belts are easy to change, and some are next to impossible. If you have to disassemble anything be sure that you note the position of everything as the timing of the tray, door, laser and most items in the unit is very critical. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Memorex Audio Players & Recorders
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Denon DCM-290 5-Disc CD Changer / Player Logo
336 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
