Question about HP DeskJet 6122 InkJet Printer
Printing problems ink light is blinking even though cartridge has been replaced on hp 6122 i have replaced color and black. help~ been all summer without and it is time for school to start back.
  • Anonymous Aug 14, 2008
    how can i solve my problem in my printer in this the same case?
There are a couple of things that you can try.
1.) Using the "Clean print heads" Utility on the printer.
2.) Unplug it and let it sit for a few minutes (it shouldn't take that long, but to be on the safe side). This will clearly the RAM and possibly the issue.
3.) If you are not using genuine HP cartridges this could also be the problem. I don't know if the 6122 implements CRI's cryptography firewall chip, but if it does "generic" or refilled/remanufactured cartridges won't work.
4.) As odd as it sounds, sometimes just letting about 15 pages run though clears the problem up; I would try this as a last resort (or before buying the expensive HP cartridges) because it will use up your paper and ink.
Good Luck!
Posted on Jan 05, 2009
  • 3 Answers
The printer is fine but the ink cartage is new but the ink will always come out to lite
Posted on Sep 26, 2008
    Sergeant:
  • 359 Answers
Unfortunately there is little you can do to troubleshoot hardware malfunctions like this you describe. Especially on inkjet printers. You would be better off getting a replacement printer.
Make sure you take the plastic guards off the cartridges, other than that there really isn't much more you can do.
Posted on Aug 12, 2008
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
HP DeskJet 6122 InkJet Printer Logo
462 people viewed this question
Ben Johnson
