Question about Konica Minolta Office Equipment & Supplies
Minolta Di2510 Copier
Repair Code C0910
How do I fix it?
  • Anonymous Mar 30, 2014
    how can i fix error cod c0045 on minolta di2510?
  • 145 Answers
SOUND LIKE TRAY PROB.DO YOU HAVE LCC ?
CHECK ALL TRAY
Posted on Oct 06, 2008
Konica minolta dialta di3510
The pass code for the admin mode on the di3510 should be 00000000 (8 zerros ) OR Elevation drive motor failure for the finisher /service manual
Aug 28, 2012 | Minolta Di3010 Copier
Error code C0910
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 21, 2012 | Minolta DI2510 Black and White Copier
Minolta DI2510 Black and White Copier - Code reset minolta issues?
what code do you want to reset different code different reset procedures
Nov 22, 2011 | Minolta DI2510 Black and White Copier
C0910
Hello
C0910 shows that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there's any jammed paper.
Mar 04, 2011 | Minolta DI-2010F Copier
PLEASE HELP ME WITH CODE 0910
C0910 service code means that your tray 2 is not lifting the paper properly. Most often this is caused by the tray being loaded improperly. So to try and fix this I would open tray 2 and check the loading of the paper and correct if necessary. Reset the code by turning off then on the main power from the back left side of the machine. Leave tray 2 open until the copier warms up and says ready. Then close tray 2 and wait to see if the code comes back. If it does then you have a motor lift problem or the sensor that detects the lift is bad. You can always leave tray 2 open and inch or 2 so that you can still use the copier as this will keep the code from coming on.
Good Luck and Thank You for using Fixya.
Sep 13, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Jun 26, 2009 | Minolta Di3010 Copier
L have a minolta Di 250 copier and is giving a COZ 32 ERROR how do l fix that
NO such thing as that code - COF32? - Faulty ATDC sensor. Possible causes - PWB-A, PU-1, ATDC.
May 16, 2009 | Minolta DI2510 Black and White Copier
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Sep 04, 2008 | Minolta Di3010 Copier
311 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
