Question about Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range
Any ideas? Dual Fuel Viking VDSC307-4B oven problems. Bake element won't go on in "Bake" or "Convection Bake" Mode. Replaced Thermostat and lower bake element. Have 220 going to oven terminal. Wiring looks good (no scorching or bending), unit a little over one year old. "Selector knob" clicks fine. What next? Repairman or another part replacement?
    President:
  • 497 Answers
I would attempt to replace the relay switch. Manual switch 220 V is dangerous so relays are used. Follow the wiring back from the element to the relay. If that fails get a repair guy out for an estimate. Tough to figure out without physically witnessing unit.
Posted on Aug 20, 2009
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Bake Element
I would start by checking the temp sensor of the bake temp settings. Pull it and its most likely bad your thermostat control, also did you ohm out the element before installing it i have bought many new bad ones as well. anything else just ask.
Apr 05, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Hello Gene I have a fridgaire plcf489ccf Dual fuel 40 inch range. When in bake or convection mode the oven does not come up to selected temp. i have replaced the probe . It can take an hour to get up to...
Hey Joe,
What ya would need to check for is see their is 240 volts power going into the oven,the radiant bake element and the convection bake element are 2 different elements so i doubt that both of them are bad at the same time, (have ya checked on the broil to see if it heats quickly?) if the broil heats up fast i would say the incoming voltage is ok and would be looking to the control board as being the problem since ya have already replaced the thermostat. If ya have a volt meter you could set the oven to bake and see if 240 is at the bake element of if its less and being restricted by a burnt relay on the control board.
GENE
Oct 17, 2011 | Kitchen Ranges
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Nov 25, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Open Questions:
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
89 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
