Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson DC04 hello, my dyson seems to run ok in upright but when i tilt back the motor sounds like it is struggling, do you think it's down to the rollers being to low and can you adjust height of rollers to overcome said problem? yours chris
  • 372 Answers
Hi.
If the motor is struggling check to see how easy it is to rotate brush by hand it is stiff to rotate the bearings in the roller may be siezed or the roller could be clogged with hair etc check it & let me know what your findings are.
Chris...
http://dysonmanuals.llc.nu/
Posted on Aug 17, 2008
The cleaner will not click down to stand up unaided. Any ideas
Hi Lynette, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson DC04. From what you've described, it sounds like the valve carriage needs to be realigned. This is quick and easy to do by following the steps shown in our video guide:
I hope this helps, but if you'd like some further advice from our experts after giving this a try, just call the Dyson Customer Helpline on 0800 298 0298 (UK) or 1800 239 766 (AU).
Jun 03, 2015 | Dyson DC04 Upright Vacuum Cleaner Pre...
Dyson dc04 new belt snapping and I think the brushroll is broken as only part of it rotates when i manually turn it
I'm sorry to hear you're having difficulties with your DC04. From your description of the issue, it sounds as if it's probably best if you get in touch with us directly so we can determine if a replacement part is necessary. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 23, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
When I tilt my Dyson DC 17 Animal upright so that I can use the hose, the vacuum powers off. As soon as I tilt it back down, it turns back on.
I'm sorry to hear you're having difficulties with your DC17. When you stand the cleaner upright, the brushbar motor is designed to shut off automatically. However, the suction motor should continue to run unless you turn it off manually with the on/off switch. If both motors seem to be shutting off when you stand the cleaner upright, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Jun 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Animal Dyson DC07. While cleaning the filter I laid the vacuum down . Now I can not get it to stand upright
Have a look at the following link:
http://www.dysonmedic.com/DC04%20Folder/DC04%20upright%20fix.html
It is aimed at the DC04 BUT at the very end of the article, it says the DC07 suffers the same problem and the fix is very similar.
Dec 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller does not turn
It sounds as though you need to replace the drive belt. The necessary part is available from http://www.espares.co.uk/dyson/dc04/p/1086/716/4. Fitting it is tricky, but guidance is available from http://www.dysonmedic.com/DC04%20Folder/DC04%20belt%20change.html
Aug 02, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson dc04 motor runs but has no suction.
I would make sure it is the motor first by isolating the sounds to just the motor. Take off the dirt cup, both filters, and belt, then run it and see if the sound is still there. If it is, you need a new motor. If it isn't, you need to look for a clog, or bad roller bearing.
To take the motor out first undo the wiring running down the backside of the unit inside of the switch housing. Then take the four screws out that hold the outer motor housing on, and the rest pops apart. Once you get inside, the gaskets make it a really tight fit, so you might have to hit the motor shaft with a rubber mallet to get it out and use penetrating oil on the bottom gasket to get the new motor to slide back in.
I guess there is no easy explanation. Let me know how it goes.
Dec 01, 2008 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
134 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
