Question about Sharp Microwave Ovens
Display failed. Can I get a replacement part? Model is a 1.2 cu. ft. R360D. It's probably 10 years old (or so).
  • Sharp Master
  • 9,086 Answers
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
I replaced clock panel turn power on nothing is there a code
If no display---you may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps.
May 12, 2015 | Kenmore 4888 Elite 30" Built-In Microwave...
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Sparking when turned on
Had to of these to do this at work means it's time to replace it not worth fixing u can replace it for allmost for what's its worth
Feb 08, 2012 | Maytag 2.0 Cu. Ft. Over-the-Range...
I have a 5 year old Samsung microwave oven, model MD800WC. It sits on the counter. The display lights up and the light goes on when the door opens - so there is power and there is a connection. BUT, the...
looks like your control unit pcb is not having power, most likely a varistor blow up on the input power line to the board, just replace it and fix the melted track on the board.
Sep 22, 2017 | Samsung 1.8 Cu. Ft. Over-the-Range...
Main board
Not likely it's the touch buttons wearing out you can buy the tocuh pad and replace it it's not that expensive, go to www.appliancepros.com and find your model and look at the parts list and find your part, they have a break down of the parts assembly.
Nov 12, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Is the 1.1 cu ft 1100 Watt model: jes 1139bl sold by Home Depot the same as the 1.1 cu ft 1100 watt model sold by Lowes ? If so, what is the model number of the lowes unit ?
A quick check of the Lowe's Web site show the following GE 1.1 cubic foot microwave models:
JES1142SJ
JES1139WL
JES1139BL
JE1160WD
JE1160BD
If you still have any doubt, I'd call Lowes.
Aug 23, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
