Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
F/DL Error Code
All:
I appreciate any and all help I can obtain. Our Kenmore HE3T washer we purchased 2 years ago started throwing a F/DL code Error 1.5 years into our purchase. We have been very happy with the machine until now. Normally we would cancel out the error by stopping the wash and opening and closing the door. Now the problem is getting much worse. We must unplug the machine to clear the error. Usually we get an F/11 to follow. Now we have to cancel and restart the wash and pray it completes without repeating. I have found a lot of chatter regarding this issue on the web, many suggestions, but before I spend $$$$$$$ I want to ensure I am heading down the right path.
  • RichardK08 Sep 15, 2008
    I appreciate the response. I actually popped the top about three weeks ago. I checked all the plugs. One was loose and I reconnected it. I also installed a high end power filter. This is betweem the outlet and the wash machine.
    Since then we have only expereienced 1 F-11 Code and no door lock error. Keep your fingers crossed.
    Again thanks for all your help...
    Novelist:
    Champion:
  • 261 Answers
Starting with F 11 which is a serial communication error. I would pop the top by removing the three screws from the back top and look down the right front side and look with a bright light for any thing broken or loose. Then I would unplug the washer and trace the power connect back to the ccu, usually has three pink wires and also the two with blue wires. Although it has a serial error sometimes the power is corrupt because the connect is loose or corroded. I would un plug and re plug the three sets of cables, the blue usually have ds or ds1 as a label, the second is replacing the latch/lock/ sensor and doing the plugs.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094190&PPStack=1
Here is a link with part info.
Posted on Sep 15, 2008
SOURCE:
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2011 | Kenmore HE3T Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3 (not HE3t) F11/dL error code
The part number for the CCU under the model number you have listed is 8182687. There is also a refurbished version of the CCU you can purchase for less (part #8182237R).
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. The CCU will be listed as item 15 (15A for a refurbished version) under the "Control Panel Parts" section.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: The cheapest site I found the CCU listed (NEW) was pcappliancerepair.com. The cheapest (REFURBISHED) is searspartsdirect.com.
Mar 02, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clicking and F dl error
Error code stands for door lock. May need a new door lock.
Oct 23, 2009 | Kenmore HE3T Washer
Kenmore HE3t font load has fault code DL and will not start cycle or stops in mid cycle with this code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2009 | Kenmore HE3T Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3t DL code
My husband and I had this same problem, but after visiting this website and reading through some of th posted solutions, we were able to fix our problem. Our 3-year-old Kenmore Elite H3 would not start on any cycle. It kept flashing the error code "dL/F", which we found out means "door lock failure." Taking advice, we unplugged our machine, removed the top panel, and rechecked the wiring. It worked! We think the wiring may have become loosened over time due to the jiggling vibration of our machine. Hope this helps you!
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
F DL Error Code
If you were already experiencing the F11 error code and now experiencing the Fdl error, this more than likely is a failure of the Main Control Board. F11 is a serial communications error associated with the Main Control Board, while the Fdl error is either a failed Main Control Board and/or door latch. You can replace the door latch first to see if the error goes away, but I would almost bet you have a control board problem since you were already experiencing an intermittent error code associated to it. Let me know if you have any further questions.
Sep 16, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
98 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
