Question about Rowenta DG-980 Iron
What should I do ?
What should I do? I have an old Rowenta DG-980 Iron but it not working very well any more, and I would like to know if I should buy a new one of the same Iron or if I should buy the new Rowenta DG5030?? Which one of the two will be better for a busy housecleaner user? I sorry about my English ( I'm learning how to writing and speaking this language ). Thank you.
    Scholar:
  • 70 Answers
The old Rowenta DG-980 is a consumer grade machine but with commercial quality function and features. My gal who worked at a dry cleaners many years ago loves the DG-980. Here is the scoop on how to get it going if just cleaning it is all it needs (our used one had the same problem and I fixed it by doing the following:
Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion.
To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time).
After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water and debris that was is in the system. Hope this helps :O)
Posted on Sep 16, 2008
The DG5030 has had terrible reviews because it spits out water and rust when the tank of water is not full (or filled with fresh water). This is very difficult to do since the water tank is not clear and you can not see the level of water.
the DG-980 is the best! Have used one for the past 4 years!
Posted on Sep 08, 2008
SOURCE:
How to clean rowenta expertese iron DG9020
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Jul 10, 2010 | Rowenta DG-980 Iron
Rowenta Steam and pressure iron does not turn on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 20, 2009 | Rowenta DG-980 Iron
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
New face plate
Google California Electric Service in California, they are on Burnett Ave. Sorry I am having problems posting solution with my ISP connection.
Aug 04, 2008 | Rowenta DG-980 Iron
Missing hose for cleaning
In California, the name of the place is
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
You were unclear if the faceplate is on the steam generator or the iron. Anyway the repair center for Rowenta above should help you. Be prepared to pay for shipping, get a firm estimate and insist on old parts be returned with the repaired unit. If it is the soleplate assy, it is around $75 or so.
Jul 30, 2008 | Rowenta DG-980 Iron
No steam, button jammed
I posted a similar fix under Rowenta DG-980 troubleshooting section. You may be able to pry off the soft rubber cover and access the switch assy and initiate a "surgical procedure".564568
Are you working on another iron similar to the DG-980 posting elsewhere on the FixYa website?
As for the Rowenta manufacturer, you can "Google" the Rowenta website at http://www.google.com typing in Rowenta and looking specifically for the Rowenta home website to get manuals, PDF reader and other good stuff. Please advise if your problem is fixed. I'm in SoCal and been to the UK only once.
Jul 10, 2008 | Rowenta DG5030 Iron
Water leaks from the bottom of the iron. Rowenta expert GV2380M steam iron
Yes it is from the bottom of the boiler from a small opening, I guess a vent. Thank you for the help.
Jul 06, 2008 | Rowenta DG-980 Iron
Stean escaping around cap
If you need a new sealing plug or parts, since I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
Hope this helps, good luck and keep in touch.
Jun 28, 2008 | Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
476 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
