I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
How much was the lamp? I'm having the same thing happen. My is a wega 60in, it just started. It will be on for couple hrs and then off and on a few times and then it's fine.
if it blinks red, the # of blinks = error code
if it blinks green and comes back up, you need a new lamp
