Question about Kenmore 15864/15862 Top Load Washer
Kenmore top loading washer model 110-24962301
My washer is leaking from underneath. It appears to be close to the front that the water is coming from. How do I even go about checking to see what the problem is? Are there hoses or something that could be lose? Please tell me what the easiest way in determing the issue is.
Thanks...
Patty
  • 550 Answers
The drain hose connects to the pump with a flexible coupling about 2inches behind the front case. to check
Remove console
  • remove edge trims from console
  • remove phillips head screws from corners of console(under trims)
  • slide console forward, lift up flip over
remove body/case
  • remove body retain clips from under console(not how they fit for reassembly)
  • remove lid switch connector
  • lift body ~1 inch slide forward and off
pump and entire workings are visible, leak site should be visible at the hoses couplings etc
Posted on Aug 20, 2008
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Model 110 top loading washer
May be the water pump! Give the model number in full.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Water leak
Replace the water pump. They will leak.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leak on occasion front load washer purchased around 2002/03
You need to remove the kick panel (under the front door). There are two screws at the very bottom of the kick panel, one in each corner.
This will give you visibility to see where the leak is coming from.
On the right hand side is the drain pump. The black hose goes from the pump,out the rear and into your drain pipe. It is secured by a clamp and is one possible source of leak.
If that connection is dry, look underneath the tub where the two parts, front and back of drum, come together. there is an o ring sealing the two sections and this is another source of water leak. (major problem is this is leaking)
Failing this you will just have to trace the source of the leak. You may have to take off the top of the washer to check the water inlet hoses which run on the top of the machine but would still show as a leak under the machine. Good luck.
Jun 11, 2008 | Kenmore 43042 Front Load Washer
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
232 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
