Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Water from chilled water dispenser on my amana side by smells bad and tastes bad
See above
  • Anonymous Mar 13, 2014
    Chilled water won't shut off. intermittent problem. replaced freezer door switch, still occurs. could this possible be related to the fill valve?
    Sergeant:
  • 409 Answers
Its either the icemaker itself or could be water actuator padle needs replacing.
Posted on Sep 13, 2008
Amana ARSE667BS1 refrigerator chilled water taste bad but ice doesn't.New filter and new reservoir.
Run 3 to 5 gallons of water through the new filter to flush it out and prime jt
Sep 02, 2016 | Amana Refrigerators
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Drinking water has a bad taste and smell.
You will have to trace where the foul smell comes from by tracing the water line and testing the source. Check if it is before or after the filter you get the smell, if it is before the filter, you need to check if it is on the line which comes from the source or it is from the source. Most likely cleaning or probably a replacement of the part if cleaning does not help.
Sep 21, 2009 | KitchenAid (KSRD22FKST) Side by Side...
BITTER SMELL AND BAD TASTE IN ICE IN FREEZER
try putting an inline filter in your water supply line before you hook it to the waterline
Jul 12, 2009 | Refrigerators
Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Jun 23, 2009 | Refrigerators
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
138 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
