If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
