Question about Canon PIXMA MP750 All-In-One InkJet Printer
Canon MP750 not printing
My 3e black ink is not printing at all anymore.  I did test runs and deep cleanings and still nothing prints in the test run for the 3e section.  What do i do?  Another guy on this website mentioned print head clog buster.  on this site:
http://www.shopdyesub.com/Clog%20Buster1.htm
Does this really work?
Please help, I need my printer and soon!!!!
  • mxaxnxdxa2 Sep 04, 2008
    Mine's doing the same thing.. it'll copy just fine because the black turns kind of a grey/blue.. but it won't print anything black. I've switched out both black ink cartridges, made sure they're seated properly, done all the maintanence on it.. still won't print. When I search "printhead", even on the canon website, it brings up ink tanks. Considering this is my office printer.. it's pretty much ruining my week.
I have the same problem. The 3e Black looked fine, and the LCD said it was half-full, but would not print in the text pattern and nothing black prints. I replaced the 3e cartridge and it still doesn't work, and still says half full even though it is brand new. This seems to be a repeatable problem for the MP750.
Posted on Oct 07, 2008
  • 4 Answers
I had a similar problem. I put in a new ink tank but did not seat it properly. When I tried to print nothing came out. Worse yet, apparently it burned out those jets in the print head! A new print head fixed my problem. I got it on eBay and am very satisfied.
Posted on Sep 01, 2008
SOURCE:
Cartidge 3E Black not printing
make sure the smaill tape on the ink cartridge is peeled off.
Jul 25, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Oct 24, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Kind of an X-file situation there. You should try an other cartridge, maybe that one is defective
Feb 03, 2008 | Canon PIXMA iP4000R InkJet Printer
PIXMA MP780 - not printing black chararcters
All the people in this forum with a Canon ink printer not printing black, especially if you tried replacing the print head and still have the same problem.
Your purge unit/capping assembly is most likely clogged. This can be caused by using crappy ink cartridges and by not using the printer for exptemely long periods of time.
You will have to disassemble the printer. First open the lid so the print head moves into the centre of travel. Unplug the power cord. Remove the upper case (can be hard to do, usually they're snap-together).
Remove one screw on either side of the print engine and remove the engine from the lower case. Unplug the cables that go from the main board to the purge unit (the large black assembly covered with old ink, located on the right side of the printer where the head usually would stop after you've finished using the printer and shut it off).
Now you have to remove that black purge unit from the right side of the engine. Usually there are two screws holding it in place.
Give the unit a bath, carefully removing old ink from everything so the unit looks like new. (be sure to remove the one motor first or you will ruin the motor). Check the bottom and make sure the two small clear rubber tubes are not clogged with old ink. Clean the absorber off (the pad in the lower case) if it has ink piled into a small hill shape.
If the tubes look like they might be clogged, you'll have to find a way to clear them out. I can do it in my shop, but it's too in depth to explain.
Reassemble the printer, connect to a PC and do a few deep cleans and print out a test page. Problem solved.
Remember, if one colour is not working it's because the head is clogged. You will have to do multiple cleans to get it to work. If it still doesn't work, then either it's REALLY clogged or the purge unit is not working because it's clogged. If you buy a new print head, then the only thing left is the purge unit. Be brave and try the disassembly and cleaning, or take it to your local service shop.
We charge $45 CDN for a job like this.
Rule of thumb: If you can get it fixed at a shop for 1/2 prince of a new unit, go for it.
Jan 02, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP750 All-In-One InkJet Printer Logo
414 people viewed this question
Clive
Clive
old marine
old marine
Ekse
