Question about HP LaserJet 1022 Printer
HP Laserjet 1022
Hello;
I have a HP LJ 1022 that we just changed cartridges. Upon changing, we get a paper jam that gets about 1/2 way into the printer (up to the cartridge). Jams the same way each and every time, same amount of paper curl, and identical jams.
I initially thought that it was the new cartridge, but when I put the old cartridge back in, it does the exact same thing. So that leads me to believe that it is the printer and not the cartridge.
Your assistance is appreciated.
  • alan297 Sep 15, 2008
    Same problem as woodyacme
  • ravi626 May 15, 2009
    same problem described above. the paper gets pulled about 2 or 3 cm in, then wrinkles towards the left (facing the printer) and gets stuck, then it stops trying. i tried to refeed it several times, but to no avail...
Try to clear dust from cylinders..
I had similar problem and I cleared dust from cylinders with ear sticks and destilled water.
good luck :))
Posted on May 20, 2009
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
Cleaning Page
Please, read this maintenance document first and try again.
Dec 02, 2011 | HP LaserJet 1022 Printer
Triangle red light is flashing HP laser jet 1022
check paper jams, open back over check paper path sensor flag and cartridge sensor flag for dislocation or spring mis place..
Sep 13, 2011 | HP LaserJet 1022 Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
The lights on the top are flashing. i dont kno what to do to get it to work
You have a paper jam or you are out of toner.
Change the toner cartridge if no jam is found.
Aug 03, 2009 | HP LaserJet 1022 Printer
White stripes on the printed text
The drum sounds like it is failing. This should be replaced when you change the toner cartridge. Have you got a spare cartridge you can test with?
May 31, 2009 | HP LaserJet 1022 Printer
Paper jam
A toner certainly can cause a paper jam. However the jam would be located in the area of the cartridge. Easiest way to check is swap the new with the old or a known good toner and see if the problem follows the toner.
hope this helps
Mar 17, 2009 | HP LaserJet 1020 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
HP LaserJet 1022 Printer Logo
179 people viewed this question
Ben Johnson
