Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Paper Jam When a copy is made, the paper gets jammed in the rollers when it is about to come out. It happens whether you have one sheet or 20 sheets of paper in the tray? Can you help?
  • Anonymous Oct 15, 2008
    Mine happens where the paper is going into the machine from the tray.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..first thing is to try another type of paper.
Posted on Aug 19, 2008
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
PAPER JAM. NO PAPER IN MACHINE BUT STILL GET PAPER JAM SIGNAL. OCCURRED IN MIDDLE OF PRINTING PG 2 OF 2 PG JOB. I CAREFULLY REMOVED THE HALF-PRINTED SHEET, PRESSED "OK" AND IMMEDIATELY GOT "PAPER JAM"...
the first step you should do is.
> unplug the power cable from the printer and then plug it back in.
> clean all the rollers which are there.. front rollers, adf rollers.. rollers at the back ..
> if does not work then. perform a reset.
( unplug the power cable from the printer while the printer is on. and after that press and hold the 6 and the # key on the printer. while holding and pressing down these keys plug in the power cable and wait fr 20 secs and then release the buttons.. )
this is a reset..
after this reset it will take few minutes to initialize.
These steps will possibly resolve the issue.. if not i must suggest to to get a new printer..
Oct 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper shift leads to jam.
first thing is turn off the printer..
clean the rollers using a lint free cloth(dry cloth)
connect the printer to the wall outlet..
turn on the printer..
try to make a copy..see if it works..
Mar 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
207 people viewed this question
old marine
old marine
