Question about Nintendo Video Game Consoles & Games
Characters move to bottom right of touch screen by them selves.In brain training it does its own choosing... What should we do as it is only 10months old...
  • 69 Answers
You will need to take oit back to where you purchased it, the touch screen is sticking, no way to fix it other than replace the screen.
Posted on Aug 12, 2008
Im trying to put my email but they comes another character
It is because of keyboard layout . I think it must be set to different language.
I would suggest you to try changing the input method :
To add a keyboard layout for a language
  1. Swipe in from the right edge of the screen, and then tap Search.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then clickSearch.)
  2. Enter language, choose Settings, and then tap or click Add a language.
  3. Choose the language that you want to add a keyboard layout to, tap or click Options next to the language name, and then tap or click Add an input method.
  4. Browse the input method list or use the search box to look for the keyboard layout you want to use.
  5. Double-tap or double-click the keyboard layout, and then tap or click Save.
To make a keyboard your default keyboard
To set a keyboard as your default keyboard, follow these steps:
  3. Tap or click Advanced settings.
  4. Under Override for default input method, choose the keyboard layout you'd like to be your default keyboard, and then tap or click Save.
Thats for Win 8, I am not sure about you OS.
Try the above if the issue persists please let me know what is the OS ?
Are you getting any other language or its just the issue with symbols.
If you have any video please attach so that I can help you better.
Feb 26, 2015 | HP ProBook Computers & Internet
Tip
Brain Age Check Selection Menu
When you go on Brain Training, if you want to do a Brain Age Check, hold down the select button and you can then choose which tests you want to do yourself! No more awful memory tests!! Oh, and actually listen to the tips that the man gives you, they really will help! ENJOY!
on Feb 02, 2009 | Nintendo Brain Training: How Old Is Your...
How to reset ipod
Fully charge your iPod touch to prevent draining your battery during the factory reset.
Touch "Settings" on the device's Home screen.
Select "General" from the "Settings" menu.
Choose "Reset."
Select "Erase All Content and Settings." A confirmation window pops up on the bottom of the screen.
Touch the red confirmation button on the bottom of the screen.
hope this helps
Oct 14, 2012 | Apple iPod touch Second Gen (8 GB,...
Dr Kawashima's Brain Training-how do i reset profiles?
To reset/ remove the profiles you need to load up the profile you wish to delete and then touch "other options" once there select "settings" and you will see the option to "erase personal data" select it and confirm the erassure by selecting yes.
I hope this helps,
Regards,
SOD69
Apr 11, 2010 | Nintendo DS Lite Console
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Brain training incorrect screen orientation
some games are like that there is no way to change it
Oct 12, 2009 | Nintendo DS Lite Console
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Hello: Train won't move
CHECK FOR SWITCH ON BOTTOM OF TRAIN
Dec 07, 2008 | New Bright Toys
Ds lite does not recognise the letter K when using brain training
Recalibrate the touch screen in the DS main setup menu.
If still having problems then you might need a new touch pad for your screen to get it working right again.
Look for repair guides here or using google.com if you intend to repair it yourself as it is not really a difficult repair if you have the right tools (triwing and philips screwdriver) and the parts (ds lite touch pad).
Regards
Nov 14, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
