Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
DVR 6200/6400T Upgrade
After june 08 upgrade whenever recording a programme that is a series another box ask you whether you want to record the entire series, you cant accept or decline and have to turn the recorder off from the electricity supply switch to reset the recorder. Any ideas?
  • 2 more comments
  • SC54 Aug 26, 2008
    have just bought a Sagem DTR 6400T and evry time i try and record a series on C4 the box locks up and i have to switch off at the mains to restart - tried tuning the aerial to get a better signal but both strenght and quality are in the green - any ideas
  • normankitche Oct 19, 2008
    My 6400t locks up every day when using Ceefax, have to switch off at mains to re-set. Only had it 4 months but Argos will not exchange it.
    Remote Control will not send codes using the OK or surrounding buttons.
    Sagem want £29.99 for new control and won't listen about useless machine. Any advice accepted or refuse collector will get it.
  • able005 Jan 14, 2009
    I have similar problem..... BBC news feed OK, CH4 teletext loads, but selecting a news item locks up the box
  • Anonymous Mar 23, 2014
    cannot hear the recorded programms without turning the volume up as high as it goes
Get version 8 of software
Posted on Nov 25, 2008
How can i record series options
From the Programme Guide select the programme you want and press OK. Then select the 'Record the Series' option. Note that this option will not appear for one-off programmes such as films.
Aug 03, 2014 | Humax PVR9300T HD DVR
Www bt com
I would think that depending on what format the recordings are in, you should be able to keep them. Basically you just have a hard drive with things recorded on it, so I would take it out and connect it to a PC and see how it comes up.
Apr 26, 2014 | Computers & Internet
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
DISH Network DVR-625 DTV Receiver- Is it possible for me to replace the hard drive in this unit with a larger one? Say a 1TB? I build computers so Im familiar with the mechanics, just need to know if the...
Hi gehrlichman, my name is Mike Houston of DISH Network andI was going over your post and seen where you were asking about an externalhard drive to get the recordings off your 625 DVR receiver. To do that you willneed to upgrade to our VIP HD series receivers, if you get the HD DVR receiveryou will be able to add an External Hard Drive to get the recordings off. Iwill send a link to tell you all of what's needed.
Mar 25, 2011 | DISH Network DVR-625 DTV Receiver /...
Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
Mar 15, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Problems with a dv3 16000 Nuvico digital recorder
did u try using a cd cleaner the dvr only accepts cdr not dvd try using the usb port with a thumb drive to see what happens
Jul 05, 2009 | Nuvico NVDV3-16000N
Unfortunately, there is no way of saving your DVR, i would ask Dish for an upgrade to a Vip series rec, for example a 622 or 722 which can allow the use of an external hard drive. it also sounds like your root problem is with the voltage in the outet your dvr in connected to, try to plug directly into wall, if it is already, have an electrician check your voltage to prevent future issues.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
510 DVR has to reload sat signal when accessing recorded events.
There was not a software upgrade in the last month for the 510 according to Dish Network. With that being said the issue is more than likely a bad hard drive. If you have to replace the receiver ask about a non dvr model that supports an external hard drive. This will allow you to keep from paying the dvr fee every month and allow you to have better control of your recordings eg. more record time, saved recordings if receiver needs to be replaced etc. There is a 39.99 one time fee for Dish to enable this feature but it is well worth it in my opinion. You may also want to check out the line of Sling media they have available also if you are an avid TV fan.
Feb 20, 2009 | DISH Network DVR 510 DTV Receiver /...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Have questions about your upgrade? We've got the answers. What do I need to do to receive my upgrade? Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically. When will I receive my upgrade? The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide. Are all DIRECTV DVRs receiving this upgrade? No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past. I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade? No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling. Will any of my DVR settings be changed as a result of the upgrade? Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output. To change Channel Banners, Channels You Receive and Favorite Channels preferences: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Channels" To change Spending Limits: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Parental Control" To change Dolby Digital Settings: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Audio" 4. Select "Dolby Digital" and "Digital Output" Will I be charged for this upgrade? No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost. What happens if I don't have my phone line plugged into my DIRECTV DVR? You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers. How will I know when I have received my upgrade? You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have. Will the download delete any of my currently saved programs? No. All of your saved programs will still be there for your enjoyment after the installation. Once your upgrade is complete... How do I activate the Grouping (folders) option? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change groups to ON. SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option. How do I sort alphabetically instead of by date recorded? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change sorting option to Alphabetical. SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort. Some settings will restore to factory defaults when the new software is download
Aug 19, 2007 | RCA DRD485RG DirecTV DTV Receiver
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
1,304 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
