Question about Technics SL-1200MK2 Turntable
Tone Arm The problem that I am Having is with the screw on top of the tone arm. It is too tight. The needle stays in the same place on the LP. I have tried to loosen it and have damaged a number of screwdrivers. The screw is stuck. Any suggestions on how to loosen it ?  Thanks...Dj Mike Music PHX AZ.
  • soundonsound Nov 02, 2008
    The problem sounds very similar. The tone arm is very stiff moving left to right. It's been sitting on a shelf for 12 yrs and I need to remaster an album onto CD. The neddle skips and stays in one place. I tried to increase the wait but that didn't help either. What can I do??? I have very good fixing skills including soldering etc...
    Wayne
  • 33 Answers
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Posted on Aug 14, 2008
Marantz 530 skips after playing only 30 seconds the tone arm won't progress. It consistently stops (skips) regardless of whatever album at the same place
Make sure that the wires leading from the tone arm are not binding. And you might also want to check for bearing friction in the tone arm. Under light stylus pressure conditions, low friction is mandatory.
Mar 22, 2015 | Marantz Audio Players & Recorders
Needle slides across lp
It might try adjusting the arm weight in the back of the tone arm. If this does not work your needle is probably bad. The point on it has worn down and this is causing it to slide across the LP. You need to replace it.
Dec 11, 2013 | Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
I have recently removed the tone arm assembly and replaced the tonearm rest on my 1210's and now the tonearm is stiff horizontally so it stays in the same place and won't move across with the groove....
Check the arm wires have not got caught around the anti skate mechanism.
Did you adjust the screw / lock nut on top of the arm?. It's not supposed to be moved but if you did it might be to tight.
May 19, 2010 | Technics SL-1210 Turntable
Tone arm pulls in one direction
If the force is towards the center of the disk, it's OK, it's the antiskating force. Set antiskating at 0, set the weight at 0gr, turn around the makeweight in order to set the tone arm parallel to the disk. With the antiskating at 0 the tone arm will stay parallel to the disk in the place you leave it. With the antiskating at any other position the tone arm will stay parallel to the disk going towards the center of the disk.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FiXya link: http://www.fixya.com/users/technical114
Mar 11, 2010 | Technics SL-1200MK2 Turntable
Hi. I'm have a problem with my Technics SL-BD20 turn table I've just purchased. When putting the arm onto the LP it just skips over the surface to the middle. Why does it do that? Cheers.
Try adjusting the tone arm weight so that the arm will be slightly heavier.
If this does not help, see if the tone arm manual lift handle is operational and fully released when the arm sits on the record.
Another possible cause are the tone arm position sensors inside the unit.
Hope you can fix it.
regards
Triarcuate
Oct 01, 2009 | Audio Players & Recorders
How to adjust automatic anti skating system on a PE 2015 record changer? Had to replace magnetic cartridge and needle by an other system, and the arm pulls too much towards the external side of turntable....
Elektrotanya for electronics experts search for the word processing that will change to GET MANUAL after a while you have a manual but there should be a tool neccesay for the arm or Tone arm geometry knowledge or almost there was a tool for the novice user there delivered with the turntable because the error angle setting for the needle special if you replace the complete element with needle
Jun 11, 2017 | Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Arm Looping
ive had this problem djing in front of 700 people...Not good!! i can tell you exactly what it is, the tone arm bearings are being pinched too tight or there is a tiny piece of debris in the bearing race of your tone arm or blatentley your vinyl is scratched lol.... assuming you ve set your stylus correctly and the turntable is level on both axis???? slightly unscrew the tiny screw on top of the tone arm just enough to release the pressure on the bearings inside, but not so much that it wobbles about??? happy mixing
Jan 25, 2008 | Technics SL-1200 Turntable
Technics SL-1200MK2 Turntable Logo
357 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
