Question about Pioneer AVIC-F900BT Car GPS Receiver
Bluetooth blue tooth connects but no sound on either end
  • kbtruck Aug 12, 2008
    this unit is a pioneer avic -f900bt. the phone pairs up to the bluetooth when you call it the number shows on the screen when you press the green button it answers but no sound between either end
    i have already paid 9.95 for a answer. this problen has nothing to do with with msn media player. please give me a differt answer . this is a pioner avic - f900-bt.i need to know about the blue tooth
    Master:
  • 521 Answers
When you connect a headset (after pairing you double-click the headset's icon and click the headset service) you will hear a beep on the headset itself. When you "answer" this by clicking the appropriate button then the connection is finally established - only then the sound is routed through Bluetooth.
It seems you are doing this already. But the problem is that this only affects programs that start using sound after the connection is established, or programs that don't keep the sound channel open. I am not sure that MSN does it. You could exit MSN, connect the headset (confirm the sounds are coming through it by using Windows Media Player for example), then start MSN again and see if it makes a difference.
Posted on Aug 12, 2008
Bluetooth has power and buttons click when pushed, but does not respond.
I just got my blue tooth ear phone to work with my laptop, sounds like you want blue tooth car to pickup on your phone speech and sound. You probably have to enable blue tooth on your phone and connect to the bluetooth receiver in the car. Probably be good if blue tooth receiver is on so phone sees the signal, that's the way mine worked, it showed that device, I clicked it to connect. Hope that helps.
Jul 08, 2016 | 2008 Hyundai Veracruz
How can I fix my blue-tooth so the other person calling can hear me?
Sounds like a setting issue, i.e. you have your blue-tooth on mute. Check the instruction manual and turn mute off!
Oct 17, 2015 | Plantronics Black Marque M155 Wireless...
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
I have connected the headset Blue-tooth with my laptop there is a blue tooth connection but no sound (music).from my media player (windows) I can change the numbers but there is no music. Hetset DR-BT21G...
It seems your laptop Bluetooth could be 1.1 version and headphones are 2.1 it won't work. I would suggest wired headset or get a 2.1 the difference is 1.1 doesn't not allow high quality sound 2.1 does allow stereo sound. here is a sample IOGear USB 2.1 Bluetooth Micro Adapter GBU421
Mar 02, 2011 | Sony DR-BT21G Wireless Headset
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
When im on the phone using my bluetooth the person on the other end says i sound low or far away. how can i fix the problem?
I have a mobile phone with blue tooth and a car enabled for blue tooth. The screen in the car is asking for a code. What is it or hw can I find it?
Kind regrds Mark
Mar 02, 2010 | Motorola Mobility H710 Bluetooth Headset
Blue tooth
The iPhone is supporting Bluetooth v2.0, but for headset support only.
See the iphone specification here:
http://www.gsmarena.com/apple_iphone-1827.php
That's mean it can use the bluetooth to connect only, with bluetooth headset.
Dec 28, 2007 | Apple iPhone Smartphone
Pioneer AVIC-F900BT Car GPS Receiver Logo
155 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
