Samsung Reclaim  Cell Phone Logo
Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i try to charge my phone it says charging halted
Anonymous
Level 2:
  • Expert 252 Answers
  • Posted on May 09, 2011
Anonymous
Expert
Level 2:
Answers
252
Questions
0
Helped
82457
Points
838
Well my wife had this phone and it did the same thing and i worked for sprint as a tech and we had to replace them because it was software related this was a few years ago but if they cannnot fix it at a service and repair center you will have to file insurance claim or however your account is set up to get it replaced
hope it helps a little please be kind enough to leave me agood review if this helps
2answers
My Kindle Fire will not start
If you last charged it with the computer USB port, try charging with the supplied AC adapter instead. If you last charged with the computer USB port, try charging with the AC adapter this time. This will help isolate a bad AC adapter / power cord or USB cable / USB port.
It is important to note that if you are charging your Kindle via USB port on a computer, when many computer enters "sleep mode" the USB power is shut off at this time too. Charging is effectively halted - even though still connected. You should only expect to charge while the computer is active or when using the AC adapter.
You can also purchase an aftermarket DC charger. These are small plugs that are inserted into your auto's port or cigar lighter. They provide 1 or 2 USB connectors to plug in a USB cable. These devices are suitable to supply / charge just about any devices that uses a computer's USB port to power / charge a device. They cost anywhere from $5 and up and look something like this:
I hope this helps and good luck!
Wont charge
YOU SHOULD REPLACE UR CHARGER
DONT BUY A USED ONE
1helpful
My Samsung Reclaim phone will not turn on. When I try to charge it, it beeps and says battery charge halted. What can I do?
Try replacing the battery- it sounds as if the battery has completely shorted out. If that does not work the issue is w/ the phone's charging system
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
WHEN I CHARGE MY PHONE IT SAY CHARGING HALTED TEMPUTURE TO HIGH OR LOW
best thing you can do is buy a new battery ang use when you charging it use it indoor .
3answers
My phone is not charging
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
1helpful
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
1helpful
Samsung schu u740 charging problem
try another battery and if that does not work then take it to a mobile service center to have it fix.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
