Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Dell Latitude C800
My C800 will boot up and go to the main desktop but then after a couple minutes, of not doing anything, the screen will turn off. If I look really closely then I can barely see the desktop. What can I do to have the screen work because obviously the computer is running??
Thanks,
Jordan
  • 59 Answers
Your computer is having backlight problems thats the reason why it is so dim. you need to have the display kit replaced.
Posted on Sep 12, 2008
  • 702 Answers
Does this happen with both the power plugged and running on battery?
Check the power modes, because the screen intensity is one of the power saving settings.
Jules
Posted on Sep 03, 2008
6ya staff
SOURCE:
No boot sector on hard disk Dell C800
It sounds like you bought the computer without an operating system, if you just bought it you need to install an OS (Windows or linux).
You might be able to get recovery discs from Dell if this sytem is entitled to a windows install. Does it have a Windows OEM sticker on the bottom?
In short, You need to install an Operating System.
You can submit a form to request replacement CDs at https://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
You may need to do a ownership transfer with Dell before they will send this there is a form for this as well or you could call customer care http://support.dell.com/support/topics/global.aspx/support/change_order/tag_transfer?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Note forms are all for US customers
Feb 02, 2009 | Dell Latitude C800 Bios Battery (IMP61135)...
TRUN ON DELL C800 LATITUDE COME ON TO XP AND THE GO TO START UP M
I got desktop rebooting that was solved by memory replacement, you have to determine what worked prior to the error and revert any change to another method
Jan 29, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
hi there, you can try this unplug the powercord from the pc and remove the battery and than press the power key than replace the battery adn plug in the power cord and let it charge for a hour or so and than try it again. if it boots good if not try to press the del key right after you turn on the unit and check the settings of bios to see what they are set at and try to set it to default or failsafe than save on exit and reboot and see what that does
Dec 18, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
It turns on and shows the BIOS screen? Can you access via F2? If it shuts down, check the RAM and RAM slots! Wrong CPU can also imitate a dead machine
Dec 07, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
I need Help!
Dude, dude, dude... Dell, it's a Dell, Dude.
Easy as pie to get a System Restore disc for XP and then use it on ANY Dells you own, no need for a COA even
Nov 24, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Fit a new harddrive in an old laptop
Pls try:
1. When the Dell logo screen appears press the F2 key to enter the BIOS?COMS; or
2. There are some Dell Latitude that uses Fn + F1 (while booted).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell c800 bios
It shouldn't be the Dell Latitude C800 Battery problem,it maybe the KEY Broad or the OS itselves problem.
May 17, 2008 | Dell Latitude C800 Bios Battery (IMP61135)...
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Open Questions:
See all Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron Questions
Computers & Internet Logo
78 people viewed this question
Ekse
Clive
Clive
Alun Cox
