I doubt the fact that your memory card is empty. Do you have no music or pictures on it? It probably says free space in the Memory details panel. You should try deleting some of your files in order to make space for more, or transfer them onto a PC.
Its mean phone memory is full, you can make some space by deleting some installed application. Delete also all cache/history in your browser. If the problem persist, reset your phone to factory setting after put off your memory card. After resetting the phone, your phone memory will be empty again and you can reinstall your previous application. Avoid to install application in phone memory (always install in memory card).
It should be referring to the phone memory. Since your memory card is still empty, you can simply move the files from the phone to the external memory, which is the memory card. You can also set the memory card to be the default storage for the downloaded files, or even files sent thru Bluetooth. The configuration somewhat is model-specific but usually falls under the settings icon on the phone
Connect to a PC and see if it is in fact full. Or try formatting the card. You might also want to try if the phone is referring to the 'Phone Menmory' when it says memory full.
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
empty ur phone memory or format it 3 key format (calling+*+3) in off state and same time on your phone while pressin all 3 keys till display shows formatting try this
