Question about Nokia 6630 Cellular Phone
Headset sign my friend was playing with my cp and then she must have done something that a headset sign came on at the upper righthand side corner. And now everytime I use my cp to make calls I can't hear anything, its like blocked. Likewise when I receive calls, I can't hear anything. How do I make the headset sign disappear? I think that's the one causing it.
(Plz.read fully)
Hai friends,let me first inform u that how your nokia 6630 detects it's headset.
There are 13 connector pins at the boottom of yr cellphone.4 for usb connectivity,others for headset,mic,switch,antenna(not in order).
The first pin from left(plz. neglect the isolated pin near to the edge) is ground
(-ve) and the second one act as a sensor for detecting headset is connected.
When the normal headset jack is plugged in, it short circuits the ground pin
Posted on May 29, 2011
  • vishnupra232 May 29, 2011
    ..... it short circuits the ground pin
Thanks, I tried it already but it didn't work. And then after maybe several weeks, the headset sign just disappeared, I wasn't doing anything. I just noticed it wasn't there anymore so now I am able to use my cp again.
Posted on Oct 23, 2008
  • 51 Answers
Hi
follow my instruction may its help you out:
1 go to the settings
2 un settings you will find the enhancment
3 open the enhancment and there you will find the three options as (head set) (loopset) and(text phone)
4 press headset then it will give you the options about answering the phone fix it to no.
if this dosn't work so tell i will help you.
thanks
your friend
I wanrt to put a video on utube how do i do it
First type in youtube.com. Next you have to make a youtube account and then sign into that account. When you sign in, in the upper righthand corner of the screen there is a button that says upload. Then you click upload and follow the instructions from there.
Nov 14, 2014 | Washing Machines
Gettemoreau@gmail.com
Sign out of your friend's account by clicking the avatar in the upper-right then clicking "Sign out."
Make sure you sign out when you're done, or your friend with have the same problem.
Dec 26, 2013 | Computers & Internet
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How to sign out from facebook
In the upper right side of the page, look for account.
-After clicking it. a box will appear.
-look for "Logout"
There you have it.
Hope this helps, thank you.
Apr 26, 2011 | Facebook Social Network
Removal of a name from my friends list?
Login to your Facebook Account, Click on Account on the Top right corner, from the drop down select Edit Friends. On the Edit friends page you will see LISTS on the left corner, select FRIENDS it loads the list of all your friends on the right side you see an X sign beside add list, click on the X sign to remove the friend.
Apr 11, 2010 | Facebook Social Network
Phone has no sound won't ring menu screen is fine everything is there but sound. Volume button is all the way up. Help
it might think it has a stereo headset plugged into it. If so it will have a little headset symbol in the upper righthand corner. Mine does this now and I can only use it with a bluetooth headset
Mar 27, 2010 | Pantech C610 Cell Phone
Playing Halo3 on Xbox 360 Live... can hear other players on headset but mic doesn't seem to work. Turning mute button on wired headset on and off makes no difference. I do have a little circle with line...
Here's my best idea. Join a party on Xbox LIVE with a friend. This will let you communicate outside of Halo 3. If they can't hear you when you're in the party together, then it's your headset.
To have a friend join a party, go to your friends menu and select a friend. It will then give you the option to invite them into your party. Good luck!
Feb 01, 2010 | Microsoft Halo 3 for Xbox 360
How to change the time
If you tap and hold on the clock, an option to change it back to digital will appear.
Mike
Oct 15, 2008 | AT&T 8925 Tilt Smartphone
WIll not play
pushing the play button on the side toggles between play and pause. Make sure the hold switch isn't in the hold position.
May 21, 2008 | SanDisk SDMX1 MP3 Player
Razr v3
It sounds like there is a loose connection in there or a button is stuck. There is a magnet that lets the phone know if it is open. It is located in the lower righthand portion of screen and the sensor is located in the upper righthand corner of the keypad. Get a magnet and play with it. What happened to it? Is it still under warranty? If not crack it open and see. There are numerous manuals online for the razrs. Only for the brave or stupid, but it just a phone.
May 24, 2007 | Motorola Mobility RAZR V3
Nokia 6630 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
