Question about Linksys Wireless-G WRT54G Router
Can't get setup page for my Wireless Router
The default URL 192.168.1.1 doesn't work, and when I look at my Default Gateway setting on ipconfig - it says 72.234.23.1 which also doesn't work.
Please help.
  • Yumio Saneyoshi
    Yumio Saneyoshi Aug 12, 2008
    I did try unplugging and resetting. Same as before. Any other ideas?
  • 37 Answers
Try unplugging your router from the power supply for about 5 minutes. Also, press the reset button on it. (I think it's underneath the unit).
Then plug it back in along with the wired connection.
Then try the 192.168.1.1 address again.
Posted on Aug 12, 2008
6ya staff
SOURCE:
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2012 | Belkin Computers & Internet
My Dlink router doesn't work.. I click on save settings on the site but it doesn't save. I want to add a password and change the name but its not saving to can anyone tell me what's going
  • Open command prompt->type ipconfig and enter.check default gateway.
  • Put the default gateway in the address bar in Internet Explorer and enter...then you will get the router login page.
  • Enter the default username and password for login.
  • select the "Wireless Settings" link on the left-hand side.
You can follow this blog for more information to set name and password-http://wireless-support-squad.blogspot.in/2012/07/how-to-configure-d-link-di-524-wireless.html
Sep 04, 2012 | D-Link Computers & Internet
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
How to configure this router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. Since your ISP is Smartbro, first connect your laptop or computer directly to the smartbro modem, check if you have internet connection, if you have, click on start, then run adn type in cmd, it will pop up the dos prompt, type ipconfig/all. It will list the ip address, subnetmask, default gateway, dns server. write it down on a piece of paper.
b. access the setup page of the router and on the internet settings, manually set it to static ip address.
enter the ip address, subnetmask, default gatewat, dns server.
c. then the smartbor modem should be connected to the WAN port of the router and your computer should be connected to the port 1 or port 2 of the router.
d. if you want to connect on a wireless connection, on your router you need to setup the wireless connection setting.
if you have any query pls feel free to get in touch.. good luck
Dec 04, 2009 | Encore ENRTR-104 Router
Cant connect laptop to router
The passphrase can be seen on the router's Admin page or its usually called router's Setup Page. You can open the router's setup page using your Internet Explorer. First you must your default gateway address. Connect your computer wired to the router or you can use a computer that is hardwired to the router to check the Default Gateway by going to Command Prompt then type IPCONFIG. If you see the Default Gateway, that's the address that you need to type on your Internet Explorer like http://192.168.1.1. If you have the router's setup page opened, you can see the passphrase on Wireless tab or Wireles Security Mode
Oct 22, 2009 | Computers & Internet
How do i make my router wireless netgear dg834gx3
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Click Here for more info
Aug 19, 2009 | NetGear DG834G Wireless Router
Bought new computer and need key number for wl-520gc
Hi! there is a possibility that the wireless network of your router is secured. to check on the setup page of the router, u need to type the ip address of the router ex-192.168.1.1.. to check the ip address of the router, connect the router directly to the router and click on start, run and type cmd, dos prompt will pop up and from the dos prompt, type ipconfig/all and it will list the ip address, subnet, default gateway.. the default gateway is the routers ip address. once u got it, pull up a browser and type at the url- the ip address of the router and enter.. it will ask for the username and password, by default the username is admin and the pass, leave it blank then it will show the setup page of the router and you have to go to the wireless settings, on the wireless settings will show the type of security and password u have.. i hope this will help to solve ur concern..
Aug 15, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I'm trying to connect to my actiontecj GT704WG
hi!. reseting the router is your last option, but 1st try to connect your laptop directly to the router using an ethernet cable and access the setup page of your router and go the wireless settings of the router and you will see the wireless security and password.. to access the setup page u need to check the default gateway of your router, how? click on start, run and type in cmd, it will show the dos prompt and type ipconfig/all, it will list ur ip address, subnetmask and the default gateway.. ex. 192.168.1.1, then pull up the browser and type at the url-192.168.1.1 and it will ask the username and password for the router, u need to type in the username and password for the router so that u can access the setup page..I hope this will help ur problem
Aug 10, 2009 | Computers & Internet
Installation software true mobile 2300
hello.. u can setup ur router even there is no setup disc.. check first the default gateway of ur router by connecting your computer directly to the router using an ethernet cable.. to check the ip gateway, click on start, run and type cmd, it will give u a dos prompt, from there type ipconfig/all and check the default gateway,ex.. the default is 192.168.1.1, close the dos prompt and pull up the internet brower from the url.. type in 192.168.1.1 and it will ask the username and password.. u need to enter it, by default the username is admin and the password, just leave it blank, if didnt work try 1234.
Aug 04, 2009 | Dell TrueMobile 2300 Wireless Router...
Linksys Wireless-G WRT54G Router Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
