Question about Hoover Floormax F4300 Upright Wet/Dry Vacuum
Hoover floormax supreme hard floor machine.One brush spins the other doesn't. used one time last year.
  • Anonymous Nov 19, 2008
    Hoover Floormax. First use - only one brush rotates.
  • 3 Answers
SOURCE: Hoover model 5906-900 spinscrub
I had the same problem. Turned out to be so simple. Look down at the machine. On the right is the green spiral to indicate the wheels are turning. Right above that is a cover that can be popped off to allow access to a small filter. If the filter is blocked, air intake is blocked, and the brushes will not turn. Mine was clogged. Took the 2 seconds to remove the material and the machine was fixed!
Posted on Aug 04, 2007
SOURCE: Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
my f5809 2-3 yrs old just started not sucking the water up (wouldn't yu know it after i just lent it to my mother in law) i went over to look at it and found the rubber gasket in the recovery tank between where the water comes up and into the lid had @1/4 " piece torn out. i stuck a piese of newspaper (tempory patch) between the gasket and lid, locking the 'patch' in place and it sucks again. i found this site while looking for a replacement gasket. maybe you have the same problem
Posted on May 13, 2008
SOURCE: Hoover steam carpet cleaner brushes dont spin
There is a plastic cover over the spinner indicator. If you take the plastic cover off there is also a little filter in that area (almost like the spinner is on the floor and the filter is on the wall). If you clean this filter it may start working again. I had the same problem before and it worked for me. I found the info in the user's manual for my model. Hope this works for you as well.
Posted on Sep 04, 2009
  • 175 Answers
SOURCE: the brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Posted on Nov 28, 2009
SOURCE: Brush won't spin on my Hoover Mach 5
Snorr, I just had to thank you. You saved me alot of time, money, and frustration!!!
Posted on Mar 13, 2010
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
Left hand brush won't spin
sounds like its sticking and the sharp turn releases the catch properly try lubricating it with either oil or wd40 should ease it hopefully this helps
Apr 01, 2014 | Hoover Floormax F5300 Upright Vacuum
Motor making grinding noise and burning smell
A bit too late I fear. There is either grit from an overloaded dust bag in the motor or the brushes have worn out. Spares and not expensive.
Jun 10, 2017 | Hoover H3044 FloorMate Hard Floor Cleaner
Dirty water leaking? from cleaner.
1) you must test where is leak, for replace any hose or clamp tight , or repair some parts with Cool solder.buy it from any auto parts for fix it.
God bless you
Jul 03, 2012 | Hoover Floormax F5300 Upright Vacuum
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brush won't spin
based on the detailed information you have given i would just say BELT
Oct 03, 2007 | Hoover Floormax F4300 Upright Wet/Dry...
Hoover Floormax F4300 Upright Wet/Dry Vacuum Logo
121 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
