Question about Bissell Vacuums
Steamer will not **** up the water - Bissell Vacuums
  • Anonymous Nov 11, 2008
    I think the rectangular seal fell out when I dumped the water. Where do I buy this seal please? Spot Bot.
  • 24 Answers
There is a black rectangular seal under the front of the tank that seals to the top of the tank lid to the suction of the cleaner be sure that the seal is there and sealing properly that should fix it. If you need to order that seal or cleaner for that machine or any other visit www.stevessewandvac.com
Posted on Aug 12, 2008
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
Should you use anything more than water to refresh clothing with this steamer
I personally use a 1/4 cup of fabric softener in mine. It leaves the clothes feeling like they came out of the dryer. this wont damage the steamer or the clothing you are steaming. And they smell great too
Apr 09, 2012 | Vacuums
Steamer has quit steaming. I have not used distilled water (didn't know I was suppose to. It seams to be stopped up.
Any device that actually makes steam should use distilled water. You are boiling away the water to make steam. Everything in the water that is not water will remain in your 'boiler'. So, what to do now ... treat it with vinegar. Vinegar should disolve the minerals left in your boiler.
Thanks for your question @ FixYa.com
Sep 13, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
Forgot what kind of water to use - distilled or other wise can not find manual, can I get one - Model GS7RW Thanks, Susan
hi.
i am assuming it is the GS7RW garment steamer and not actually a vacuum cleaner.
any electrical item with a heating element should be used with distilled or de-ionised water.
if you live in a "hard water" area where the water contains dissolved calcuim salts, these will cause scaling and furring up of the heater element. easiest way to tell is to look inside your kettle. if there are white deposits on the base or heating element, your steamer will get the same deposits and work less effectively.
another option is to use the scented ironing waters available from many supermarkets for use in steam irons. these will not harm your steamer, and will also make your clothes smell nice as they come in a range of scents.
this link does have some instructions that may help.
http://www.conair.com/instruction_booklets/06PC2349%20gs7rw%20IB.pdf
Jun 14, 2011 | Vacuums
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Is it okay to run CLR or vinegar through my steamer. We have really hard water and even though we have a water softener and use filtered water, my steamer seems to be clogged
I wouldn't recommend the CLR. My suggestion is to run a cycle using white vinegar, the accepted standby for removing sediment and deposits in small and major appliances. I hope this helps. If it does, please rate my solution. Good luck!
Dec 22, 2010 | Rowenta Vacuums
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
50 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
