Question about Nintendo DS Lite Console
Buttons the L, R, D-pad up, and down fail to work at sometimes.
Those can't be fixed permanantly, just temporarily... The L button can be fixed. I dun't think the D-pad up, down and R can be fixed
Posted on Oct 09, 2008
When i brake im getting a slight grinding noise but have no warning light on dash board?
brakes have pads (sometimes called shoes) that press against a round disc connected to the wheels that go round and round to stop the car moving. When the pads wear down you get metal rubbing on metal rather than a heat absorbing material rubbing on the metal disc.If you do not get your brake pads checked they can wear down / damage the metal disc and then have to spend lots of dollars getting the metal disc re - machined smooth (this disc is called a rotor) and new brake pads.
You are correct the warning light on the dash will not light up it will light up only if the hydraulic fluid used to press the pads onto the disc fails and you then fail to stop. .
Oct 04, 2016 | Honda Civic Cars & Trucks
How to reset gateway NV51B05u Touch Pad?
There is usually a reset button on the back where you insert a small pin and hold it down for a minute. Another common way is to hold the power button down for a minute or sometimes the power and home buttons together.
Jul 03, 2014 | Microsoft Computers & Internet
Can't get new mail
Try holding down button at top to turn iPad completely until Apple logo appears on screen. That's a complete shut down. Leave off for two minutes, turn back on. If still not able to download email, contact Apple. Sometimes it's Yahoo or other provider that's holding up the works. If case, Yahoo might suggest creating new account. See if total iPad shut down works first.
Jimmy
Apr 06, 2012 | Apple Ipad I-pad
No heat dry light keeps flashing & it will not start to wash the dishes
This means one of two things. The touch pad has failed or the touch pad is locked. Hold down the heated dry button for three seconds. If that does not work, the touch pad would need to be replaced.
Appliance & Refrigerator Repair
Mar 23, 2011 | Kenmore Dishwashers
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
Only a couple of the program/adjustment buttons on my Pro-Form 930i treadmill work. Sometimes I can push random buttons and the rest of the buttons start working for a few minutes, then after a few minutes...
It sounds like either the function pad or the upper electronics is starting to fail. Also it maybe a loose connection between the function pad and upper electronics remove the upper console and inspect the connections. If you need to replace the parts sometimes with Icon products they are either separate items or they are one complete unit, you will have to call them @ 1-800-999-3756.
Jun 10, 2010 | Proform Exercise & Fitness
Needle stop up/down no longer works on Viking 118
sometimes the bobbin winder gets left closed, and that will make the machine run slowly and with no up/down button.
Jan 25, 2010 | Sewing Machines
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
Nintendo DS Lite Console Logo
57 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
