Auto aspect ratio - Televison & Video
  • Anonymous Apr 08, 2009
    how do you lock the aspect ratio - I reset mine to 16:9 and it keeps going back to 4:3 automatically
  • 36 Answers
Auto Aspect Ratio is a feature of the set that takes the signal in and determines if the signal is being broadcasted in 4:3 or 16:9 screen size and adjusts it automatically, you can turn it off or on in the tv's menu and either pick 4:3 (bars on the left and right side) or 16:9 (fullscreen) for no matter what signal is being broadcast
Posted on Aug 12, 2008
Why do i have a large line at the top and bottom of the tv
This is caused by aspect ratio. To change you have to go into set up and alter the ratio shown as 9:16 , not sure what ratio you will have . Note som tv's have an auto chaning aspect ration for films ect.
May 14, 2017 | Televison & Video
Motherboard for SHARP TV Model LC42LE620L
you probably have it set on wrong aspect ratio, go to menu/picture set it to auto it will then chose the right aspect ratio of the prog being shown/transmitted, if you have other devices running through it, make sure they are set to 16.9 or it will never look right, it is a simple mistake, sometimes there is 1 prog that never looks right, you can then roll though the pic settings manually, tiil you get the best fill of the screen, 4.3-16.9 14.2 Cinema-subtitles-etc cinema would give u a full screen of 4.3 but cut a bit off top & bottom, nothing is perfect with all the different aspects but Auto wiil do its best.
Feb 23, 2015 | Sharp Televison & Video
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
May 07, 2014 | Samsung Televison & Video
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
Syncmaster 152v repeatedly pops auto adjustment window
HI,
If you've changed the monitor recently, have you checked to make sure the Sync rate is not to high for the montior?
Steve
Nov 28, 2010 | Samsung SyncMaster 152 B 15" LCD Monitor
I have a 55cm TFT LLED-22FHD TV. The aspect ratio is 16:9. This is too wide and the images appear fat. How do I correct this.
Go to the picture menu and select a different aspect ratio. Auto sizing is useful as the TV will detect the picture size and select the correct aspect ratio, except for letterbox and super wide screen of course as your screen is not the right shape for those.
Hope this helps.
Nov 17, 2010 | Televison & Video
The picture size resets when the tv is turned off then on.
It also resets when you switch to a different Input... IF you have the Auto Aspect Ratio set to On! To set the Picture Size so that it won't change back each time, switch to the Input you wish to change (you'll have to do this for each Input separately), then go to- MENU > Picture > Theater Settings > Auto Aspect Ratio > and set it to Off. Once you've done this, your Picture Size setting will remain, even after powering off, or switching inputs ;)
Oct 23, 2010 | Toshiba 32E200U 32 in. TV
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Televison & Video Logo
1,181 people viewed this question
Top Televison & Video Experts
