Question about Canon LaserCLASS Fax 710 Printer
The volume When we fax there is a really really really loud beep. I was wondering how to turn it down. I cant seem to find it in the manual
There should be a volume button on the right hand, side of the machine
Posted on Sep 10, 2008
SOURCE:
I recently purchased a Canon PIXMA MX410 printer and was wondering if there was a way to turn the volume down when faxing? It is so loud. Thankyou.
Machine Settings
This section describes the items you can set or change in the Fax settings or Device settings menu available by pressing the Menu button.
For details on setting or changing, refer to the on-screen manual: Advanced Guide.
Sound control
Adjusts the volume of the audible tones, such as the keypad tone generated when pressing the buttons on the Operation Panel, the alarm emitted when there is an error, the offhook alarm that sounds when the handset is off hook, and the line monitor.
  • Sound control
    Selects the volume.
    • Keypad volume
      Selects the beep volume when pressing the buttons on the Operation Panel.
    • Alarm volume
      Selects the alarm volume.
    • Line monitor volume
      Selects the line monitor volume.
    • Offhook alarm
      Selects the alarm volume when the phone receiver is not put on the hook properly.
  • Here is the link to download the user guide as well:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx410#BrochuresAndManuals
    I hope this helps
    Thanks
    Please rate FIXYA
    May 25, 2011 | Office Equipment & Supplies
    When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
    Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
    Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
    How do i turn up volume on hp officejet all in one
    Adjust the volume
    The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
    the Phone Line Monitor Volume.
    The ring volume is the volume of the phone rings. The beep volume is the level of
    button press and error beeps. The default Ring and Beep Volume setting is Soft.
    The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
    default Phone Line Monitor Volume is Medium.
    To adjust the Ring and Beep Volume from the control panel
    1. Press Setup.
    2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
    3. Press to select one of the options: Soft, Loud, or Off.
    4. Press OK.
    To adjust the Phone Line Monitor Volume from the control panel
    1. Press Setup.
    2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
    3. Press to select one of the options: Medium, High, or Low.
    4. Press OK.
    Trust this is helpful. Please vote. :)
    Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
    When the fax is dialing it is very loud. How can I
    There is a setting to adjust the fax volume. Press the User Tools button on the operation panel, and then on the touch screen press either Fax Features or Fax Settings, and then under the first tab (I think it's General Settings) there should be an option for volume adjustment. You can either turn the volume down or you can turn it all the way off.
    Mar 11, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
    Make the ringer louder I cant hear the phone ringing
    Hello. From the User Guide:
    1. Press Setup.
    3. Press > to select one of the options: Soft, Loud, or Off.
    4. Press OK.
    1. Press Setup.
    3. Press > to select one of the options: Medium, High, or Low.
    4. Press OK.
    For your reference, here is a link to the user guide:
    http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
    Thanks for using Fixya.
    Sep 29, 2009 | HP Officejet 4355 All-In-One InkJet...
    Hp j3680 fax/printer is loud
    Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
    Apr 08, 2009 | HP J3680 Officejet All In One Printer
    Panafax UF-880 - volume of phone ringer
    1- incoming volume press the down arrow till you want the desired level
    2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
    Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
    How do I turn down the ringer volume on my HP 6210 Officejet
    follow the ff. steps:
    1. press set-up
    2. press 4 and then press 6 (this selects BASIC FAX SET-UP and then RING,BEEP and VOLUME)
    3. press right arrow key to select one of the options:SOFT,LOUD and OFF (NOTE: if you are going to select OFF no will not hear dial tone,fax tone and incoming ring tones)
    4. press OK....
    try this steps and give me feedback....*mrbench87*
    Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    L170 Canon Fax Sound and volume control issues
    Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
    Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
    Canon LaserCLASS Fax 710 Printer Logo
    100 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
