My digital tv is now telling me i have no signal or a bad signal and to check my ariel. I am 65 and not able to do this what really is the problem. I hate digital
  • 36 Answers
If you are using an antenna the signal is too weak to broadcast the tv station completely, it is asking you to move the antenna to get better reception, if you are using rabbit ears you can move the antenna pretty easy, if you are using an antenna that is on the roof it's not as easy, if this is the case you can go to an electronics store or Radio Shack and get an antenna booster it should help you
Posted on Aug 12, 2008
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Tv has no signal
The TV you are trying to connect to may be an older type and not a DIGITAL receiver. The old ANALOG type no longer work with the Digital applications unless to have a CONVERTER BOX.
Dec 22, 2013 | Televison & Video
When you turn on power nothing comes on
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
do vote if it helps you :)
Mar 31, 2011 | Televison & Video
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
Mar 31, 2011 | Sanyo Televison & Video
Have tried with different ariels and still cannot get any digital channels on tv can get analogue with a struggle tv keeps telling me no signal
First check there are digital channels come in your area?If yes then select digital channel to auto tune. If still have problem then need to replaced tuner.
Nov 04, 2010 | Televison & Video
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No signal coming through
Only way really is to disconnect your ariel and connect it to another ariel.
Sep 22, 2009 | Televison & Video
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
I have installed a digital ariel but am unable to get any channels. Keep getting message no signal. The ariel works with other tv in house
You may need a digital booster when sharing 1 aerial.
They are quite cheap (£5 on e-bay is the cheapest I've seen) and easy to fit.
Also the coaxial cable can make a differance, you really need shielded and with as few joints as possible.
I hope this helps.
P.S. try tuning with just the problem set connected to the aerial direct.
Aug 24, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Open Questions:
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
