Question about Hoover Vacuums
Brushes wont turn hoover 2000 dust master - Hoover Vacuums
  • 24 Answers
Needs a belt visit they have on for your unit.
Posted on Aug 12, 2008
It could be a thermal breaker that goes automatic if the filter is full of fine-dust and the rpm of the motor becomes to high and the heat dissipation will acces the thermo breaker replace dust back AND filter, second there could be if the brushes are become to short the autostop can be activated (you see a little dark pin with micro spring in the brush ) in one of the 2 carbon brushes. if so replace the carbon brushes .
A Switch or cable defect (measure it)
Aug 02, 2016 | Hoover Vacuums
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ..., Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
My hoover wont pick up. checked the belt & any blockages
Don't just check the belt, replace the belt if it's been on the vacuum for over 6 months. Belts must be stretched to almost twice their original length to be installed and will lose elasticity fairly quickly. They may look and feel fine and still turn the brush roll but may be slipping when you are vacuuming carpeted floors.
Mar 01, 2015 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 2000W dust manager cyclone- Have had this for about 2 months and the brushes stopped turning thinking that the belt had acme off turned it over to try to get in to look at belt now the bottom wheels...
By all means ~ take it back to the store... I searched for your model and "problems" and got almost 400 hits like: "cutting out", "burning smells" and just plain "dead" to name a few...
In fact one site gave this model only 1 1/2 Stars! You've GOT to see this Link!
Hoover 2000 VC338
2 months is way too soon to fail ~ unless you clean motels or hotels for a living.
Dec 24, 2017 | Hoover Vacuums
Vacuums Logo
82 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
