Question about Refrigerators
Have a Haier refrigerator, model # HTQ21JABRSS, Serial # 5894918, since I bought it have had 2 service calls, has never been right. The right vent coming out of the freezer releases water, every 2 or 3 weeks when temperatures get to warm I must empty freezer and scrape all the ice build-up from the floor of the freezer, then it returns to allmost normal termperatures. PLEASE HELP, I have a lot of spoiled food.
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. back.
Posted on Dec 22, 2006
  • 487 Answers
SOURCE: Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Posted on Apr 30, 2008
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Posted on Nov 13, 2009
  • 288 Answers
SOURCE: The samsung refrigerators temperature in side is 58 deggrees F.
the hair dryer is a bad temporary fix. The question is why does it continue to freeze up. there are a few possibilities. One is an over or under charge of refrigerant which is unlikely. It would have done this from day one. the other is that the evaporator coil is icing up due to some dust or dirt. this slows down the air flow across the coil and then the ice eventually blocks off the air flow. The fridg is like your house. It has a supply air and return air side that must be kept clean and free from obstruction. also one of the fans may not be working. This will definitely stop the airflow
Posted on Dec 06, 2009
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
Installing a Haier Vent Hood
"Here is web page.
find which model and look in "Product Support and Downloads"
If not there try calling support the phone number is at the top
Jun 09, 2013 | Haier Heating & Cooling
Would Like A Circuit Board Diagram Of A NU Cool C-R-NU1708W. It Does Not Get Cold.
the vent motor is bad looks like a leuver needs to be replaced it is stuck closed not letting cold air into the refrigerator side keeping all the air in the freezer side forget what it is called thou sorry to say you prob wasted your money on 2 boards
Mar 30, 2010 | Haier Refrigerators
Where can I get a Haier swwitching power supply
Call 800-313-8495 for Haier Parts Dept.
The upper and lower are 2 different part numbers.
Jan 31, 2010 | Haier Refrigerators
Water leaking in refrigerator on shelves, drawers, and under draw
We took the back bottom vent cover off. Clean that area of lint. We than followed the advise given to another posting of a refrigerator link. This has seemed to work for now, time will tell. However we were told most people with Haier refrigerators have problems. Thank you.
Feb 15, 2009 | Haier Refrigerators
Ice on the back wall of the side-by-side freezer and no ice
Possible circulation fan has quit, or defrost element is not working, call service.
Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
Dec 09, 2007 | One For All URC-4330 Remote Control
My Fridge is less than 2 yrs old. Yesterday I heard a clunking sound coming from the fridge
to clunk,
i have a GE model PDS22SFSALSS & it did the same thing...blinking LED & clicking, then LED went blank. i read that GE was having major problems w/ the mother board, (cost for part $ 153.75 & $79.95 for service call, they couldn't tell me the labor cost!! )on many models & were re-calling some. i called GE repair 4/8/08, got no help, then i called customer service & gave them my model & serial #. they said my box would be fixed (mutha bd swapped) for free. i bought it 10/05, they came the next day & installed new board free! start w/ GE 1-800-432-2737 .....good luck
Nov 30, 2007 | GE PDS22SIS Bottom Freezer Refrigerator
Freezer at 10 deg, fridge at 50
haier refrigerators have been known to have the cold control go bad. it only sense's the temp in the fresh food section so that would be why the freezer is still ok. The problem is the control is cutting out to fast and not letting the temp go lower. from what you said i would take that there is good air flow between the freezer and the fresh food compartment. so the only thing it could be is the cold control. I would replace it and you should be all set.
Aug 10, 2007 | Haier HTQ21JABWW Top Freezer Refrigerator
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
