Question about Samsung HCL5515W 55" Rear Projection Television
No Power Whatsoever
I had the cable company come out and hook up the TV, we powered it up for about 60 seconds and then it was like it shut itself off and will not power up again. There is not Red or Green power on or off light. It's completely dead.
  • dkn4862 Aug 12, 2008
    Thank you, might you know where it is located, I've ordered a service manual but have not received it as of yet.
    Master:
  • 623 Answers
Check the fuse first
Posted on Aug 12, 2008
  • ritchie dempacco
    ritchie dempacco Aug 13, 2008
    it's ussually near power cables
Turns itself off after being on for a while,but after about 20 seconds it comes back on automatically. I have a LAVA preamped antenna hooked to it. Is it the antenna or the analog board?
Try to set it up with no antenna, just the cable or wire as an antenna for a broadcast station. If you can just get 1 station then you can find out if the TV is turning off or the LAVA antenna.
If it goes out and comes back on it could just as easily be the power board.
Don't open it up yourself, there are hazardous voltages even with the TV unplugged!
Jul 26, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Philips 60PP9352 60 in. tv
seems there are some faulty or failed components in your set.
The mainboard or the powerboard might need to be replaced or some convergence ic chips / capasitors / resistors.
Unless you are willing todo that, I think the best solution is to take it in for service. Maybe another expert will have more exact knowledge on this problem?
Apr 15, 2008 | Philips 60PP9352 60" Rear Projection...
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My tv shuts itself off!
Quite a long "description". "How can I fix it without having to check the back of the TV or going to a repairman?" (I altered the spelling etc a little there.)
Answer: Go to the internet and search for "Magic TV Repair Wand" and let me know if you find one---
Apr 28, 2012 | Emerson Televison & Video
I used a hdmi cable on my tv with my ps3 now i put the ps3 on a standard tv usind the av cable now i cant get no picture what can i do to make it work on the standard tv ?
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts itself off again. (This will reset the video settings)
Then power it back on with the AV/Component cables only.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
Tv shutting off
it sounds like it may be a capacitor problem and it may be linked to the electricity you receive adding a battery back up of sufficient quality will smooth out the electric current and also **** up the spikes from the power and light company. I have seen many aquas suffer from capacitor failure but it may be an expensive fix.
check your electric output and see if it can handle the load for this tv.
Apr 28, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV shuts itself off
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Televison & Video
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
