Question about LG WM-2277HW Front Load Washer
LG Front Loan washing machine
My wife washed a large sleeping bag in our LG Front Loan washing machine. She now informs me the door will not unlock and she has run through the drain cycle but door will not open. Is there a reset program on the machine to try and unlock the door?
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
Posted on Aug 21, 2008
I have a large sleeping bag I would like to wash will this machine be able to wash it
You need to check what the item weighs and the maximum load of your particular washing machine
Jun 17, 2015 | Washing Machines
Lg front load washer vibration
are you washing large pillow and bedsheet? any large material that hold great deal of water will cause the tumbler to wobble out of center rotation that in turn causes vibration. stop the machine and get as much water wrung out from the large bedsheet or pillow.i get this problem when my wife wash pillow and large bedsheet. the whole house shake violently if you live in two story home.
Mar 03, 2015 | LG Washing Machines
The door not unlockings
Front loading washers have a safety feature to lock the door during washing. Try turning the power off to see if the door can be unlocked. But first, try applying a little more pressure to open the door. Pressures from washing may have sucked the door in and formed a seal.
Regards
Mar 06, 2011 | LG WD14121 Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door won't unlock even when turned off
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Jul 27, 2009 | LG Washing Machines
Door will not unlatch after wash
hi..remove the lower front panel use torx 15,reach up to the
lock and pull down on a ring that comes down below the lock
assembly and the door should open.
try this out..
thank u..
kindly rate my response..
May 09, 2009 | Frigidaire Affinity ATF7000E Front Load...
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
De error code
Hi
"dE" means that the door hasn't been closed properly. Check the inner seals of the washing machine particuarly at the bottom where water can get clogged. Also check the rubber seal around the front door to see if it has popped out or out of alignment. Also, "DE" in full letters can mean that the drain needs to be cleaned. Switch off the washing machine, pull out the flap on the bottom LH front of the machine, find the water tube and drain the water out of the LG. Then unlock and inspect the actual plastic tray/grid when twisted to unlock and pull out. There should also be a "drain" function on the main dial as a general maintenance option. Make sure you do this to keep your machine going.
Dont forget to rate this please if this solution works. Many thanks.
Mar 28, 2009 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
461 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
